Problems with my "intelligent timer"
Results 1 to 16 of 16
    Dec 2008
    Ploiesti, ROMANIA
    Default Problems with my "intelligent timer"
    I try to make an intelligent timer. Schematic is attached ; I try to explain what I intend to do ...
    Conect the PIC to power source. LED is OFF.
    When press for the first time the button, the timer begin to counting seconds while GPIO.5 is "0" and the counted seconds becomes the wipe_time, in seconds, while LED is ON.
    At next (second) press of button, LED is ON for wipe_time seconds (previously stored).
    At next (third) press of button, the timer begin again to counting another value of wipe_time (while GPIO.5 is on).
    And so on, and so on ...
    Unfortunately the hardware not react as expected ; LED is always ON ...Can figure out what I do wrong ... Thanks in advance for support !
    @ Device PIC12F675,INTRC_OSC_NOCLKOUT, WDT_OFF,PWRT_ON,PROTECT_OFF,MCLR_OFF,BOD_OFF
    Include "C:\WIPPER\Elapsed.bas"   ' just wsave(s) removed
    CLEAR
    ANSEL=0
    CMCON=7
    TRISIO=%00100000
    LED         VAR  GPIO.0 ;  sets the GPIO.0 port as LED
    wipp_time   var byte    ;  number of seconds while LED=off
    nr          var bit
    nr = 0
    wipp_time = 2
    Gosub ResetTime                ' Reset Time to  0d-00:00:00.00
    loop:
    led = 0
    IF GPIO.5 = 0 THEN
    nr=nr+1
         if nr=1 then              ' Setting wipe_time for the first time
            gosub StartTimer
            GOSUB WIPPER           ' use pre-setting of wipe_time
    GOSUB END_sett
    if nr = 2 then nr = 0          ' ready for another setting of wipe_time
    goto loop
    END_sett:
    gosub StopTimer
            wipp_time = seconds    ' seconds counts from the beginning of gpio.5 = 0
            NR=1
    GOSUB WIPPER
    Gosub ResetTime
    wipper:
    LED = 1
    PAUSE 1000
    LED = 0
    PAUSE (wipp_time * 1000)
    Dec 2011
    IO93ok
    Default Re: Problems with my "intelligent timer"
    Shouldn't it be
    Led HIGH and Led LOW
    May 2009
    I do not see any start timer sub routine in your code.
    Fratello,
    You don't wait for the button to be released.
    If it's pressed you start the timer, then immediately GOSUB END_sett which stops the timer and stores the number of seconds that have passed.
    But no seconds have passed.
    If you put a scope on the LED pin, you'll see that it's not "always on". It pulses low very breifly every 1 second.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    How can I avoid to stop the timer immediately after pressing buton ?!?
    I want to counting seconds while button is pressed ....
    Dec 2008
    Ploiesti, ROMANIA
    I did it again !
    CLEAR
    ANSEL=0
    CMCON=7
    TRISIO=%00100000
    nr          var bit
    nr = 0
    low led
    loop:
    IF GPIO.5 = 0 THEN
      nr=nr+1
         if nr=1 then
         gosub memo                ' Setting wipe_time
         GOSUB WIPPER              ' use seconds elapsed as wipe_time
    if nr > 2 then nr =  0
    goto loop
    memo:
    gosub StartTimer
    while gpio.5 = 0
    wend
    Gosub StopTimer
    Gosub ResetTime
    wipper:
    while gpio.5 = 0
    LED = 1
    PAUSE 1000
    LED = 0
    wend
    END                             ' of story !
    Thanks for support !
