Using "If then" and "and" together
Results 1 to 7 of 7
    New Jersey
    Default Using "If then" and "and" together
    I have a keypad with four numbers. I'm able to decode the keys just fine but it's the password I'm having trouble with. I'm trying to do something like this:
    IF CODE_ONE=13 AND CODE_TW0=13 AND CODE_THREE=16 AND CODE_FOUR=21 AND CODE_FIVE=32 THEN....
    but PBP gives me a syntax error. I realize this is probably archaic but I'm wondering two things.
    1. Why won't PBP let me compile this code?
    2. I realize this code is not efficient. How can I improve it?
    New Jersey
    Default Re: Using "If then" and "and" together
    Ok, so apparently I'm not intelligent enough to realize the difference between a 0 (zero) and O (the letter O)
    If there is a way to make this code better, please let me know.
    You could try a bunch of nested IF statements. It won't be "better" but it might compile to smaller code - worth a try.
    IF CODE_ONE = 13 THEN
      IF CODE_TWO = 13 THEN  'With an oh
        IF CODE_THREE = 16 THEN
          IF CODE_FOUR = 21 THEN
            IF CODE_FIVE = 32 THEN
              'Correct code
    Another option would be to use an array instead of "discrete" variables and iterate thru it with a for-next loop. Might be worth a try.
    Using PBP 2.60C, MCSP v2.2.1.1, MPASM v5.46, PIC 18F46K22.
    62 bytes:
    @   __CONFIG    _CONFIG1H, _FOSC_HSHP_1H & _PLLCFG_OFF_1H & _PRICLKEN_OFF_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @   __CONFIG    _CONFIG2L, _PWRTEN_ON_2L & _BOREN_SBORDIS_2L & _BORV_285_2L
    @   __CONFIG    _CONFIG2H, _WDTEN_OFF_2H
    @   __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _HFOFST_OFF_3H & _MCLRE_EXTMCLR_3H
    @   __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    DEFINE OSC 20
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %10000000
    TRISE = %00000000
    CODE_ONE        VAR PortB.1
    CODE_TWO        VAR PortB.2
    CODE_THREE      VAR PortB.3
    CODE_FOUR       VAR PortB.4
    CODE_FIVE       VAR PortB.5
                'Correct code
    138 bytes:
    DEFINE OSC 20
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %10000000
    TRISE = %00000000
      IF CODE_ONE = 13 and CODE_TWO = 13 and CODE_THREE = 16 and CODE_FOUR = 21 and CODE_FIVE = 32 THEN
        'Correct code
    I know, Port be is defined as output and used as input (noticed after test), but that has no impact on test significance.
    More than twice as big using single IF, nested IF is definitely more efficient. I remember reading about that somewhere recently too, can't remember where.
    you could also turn it on its head,
    IF CODE_ONE <> 13 THEN EXIT_TO_ERROR
    AND SO ON,
    Then after the last comparison you have a valid password.
    I tried four examples here, compiled for a 16F628.
    First test:
       'Correct code
    Result: 75 WORDS
    Second test:
    If CODE_ONE = 13 THEN
     IF CODE_TWO = 13 then
       if CODE_THREE = 16 then
         if CODE_FOUR = 21 then
           if CODE_FIVE = 32 THEN
           'correct code
           Endif
    Result: 26 WORDS
    Third test:
    IF CODE_TWO <> 13 THEN EXIT_TO_ERROR
    IF CODE_THREE <> 13 THEN EXIT_TO_ERROR
    IF CODE_FOUR <> 13 THEN EXIT_TO_ERROR
    IF CODE_FIVE <> 13 THEN EXIT_TO_ERROR
    'correct code
    EXIT_TO_ERROR:
    RESULT: 26 WORDS (same as test 2)
    Forth test:
    This one uses an array to hold the entered code and assumes that the correct password sequence is stored in EEPROM, starting at location 0
    Correct = 1
    For i = 0 to 4
     Read i, Password
      if Code[i] <> Password THEN
        Correct = 0
    NEXT
    If Correct THEN
    'correct code
    RESULT: 41 WORDS
    So between these four method 2 or 3 produces the smallest code - by far. Personally I think Aerostars suggestion is the easiest to read but that might just be me...
    Feb 2012
    PERTH AUSTRALIA
    Henrik , can you advise why the big dif in words count between the samples ?
