Hi Hank,
Not sure if this will help but I created an Excel spreadsheet that charted the gamma "duty cycle" values generated by the "anti-log" formula in that simple JustBASIC program I use for generating the anti-log gamma tables. Here's what the Excel chart looks like;
And if you've forgotten, here's the program I use for generating the gamma brightness level correction tables (using the free JustBASIC program as well as an example of the output window;
Code:' Leo Bodnar's 'antilogarithmic' ' gamma correction algorithm (Mike, K8LH) ' ' JustBASIC (free) interpreter ' Input "Gamma array size: "; arraysize Input " Total PWM steps: "; width Input "Gamma correction: "; gamma ' try 0.5 to 1.0 Input "Entries per line: "; entries ' FOR index = 0 to arraysize-1 dcyval = INT(width^(((index+1)/arraysize)^gamma)+.3) if(index = 0) then dcyval = 0 PRINT PRINT " DW "; else if(index MOD entries = 0) then PRINT "," PRINT " DW "; else PRINT ","; end if end if if(dcyval < 100) then print " "; if(dcyval < 10) then print " "; PRINT dcyval; NEXT index PRINT PRINT REM CLOSEGood luck on your project.Code:Gamma array size: 100 Total PWM steps: 512 Gamma correction: .55 Entries per line: 10 DW 0, 2, 2, 3, 3, 4, 4, 5, 5, 6, DW 6, 7, 7, 8, 9, 10, 10, 11, 12, 13, DW 14, 15, 16, 17, 18, 19, 21, 22, 23, 25, DW 26, 28, 29, 31, 33, 35, 37, 39, 41, 43, DW 45, 48, 50, 53, 56, 58, 61, 64, 67, 71, DW 74, 78, 81, 85, 89, 93, 97,102,106,111, DW 116,121,126,132,137,143,149,155,162,168, DW 175,182,190,197,205,213,222,231,240,249, DW 258,268,279,289,300,311,323,335,347,360, DW 373,387,401,415,430,446,461,478,494,512
Cheerful regards, Mike
