Ryan,
I’m curious about the actual results you get with your example:
myArray VAR BYTE[3]
SHIFTOUT PORTB.0, PORTB.1, 1, [myArray\24]
Why? Because PBP is not aware of, and never tracks, the array size. In fact, it isn’t an array in the same sense that other languages use arrays (like VBA or .Net). PBP only knows that MyArray[0] is a byte at address $XX. It then ‘skips’ the number of addresses you specify in your array declaration before allocating another variable to a memory location. When you use brackets, it is really only offsetting [y] from $XX. Take this example:
myArray VAR WORD[4]
myArray[5] = 123
This is a perfectly valid expression, but will result in a lot of grief. What PBP will do is insert 123 into the two byte “WORD” located at a 5 WORD offset (10 bytes) from the memory location of myArray[0]. More than likely, that address will be allocated to another variable, so that variable will be corrupted, and your program will go off into a ditch pretty quick.
So back to your problem. When you use that shift out with myArray assigned, it really only understands that myArray is a Byte. Thus, I suspect it is trying to shift out 24 bits of data, but doing so in byte sized chunks. In doing this, it’s starting with the Address of myArray[0], just as Henrick states, and moving to the next address until 24 bits are sent.
But, I could be off track here, so I’m interested in what it’s outputting.
