A little help with shifting out Arrays?
Results 1 to 13 of 13
    Sep 2006
    Indiana, USA
    Default A little help with shifting out Arrays?
    I'm having a little bit of trouble with array variables as of late. From my understanding (and R-ingTFM) to set up my array to contain three bytes:
    myArray VAR BYTE[3]
    And to access my three bytes as individuals to load data into them:
    myArray[0] = 1
    myArray[1] = 127
    myArray[2] = 255
    and then myArray should have 24 bits and if i do this:
    SHIFTOUT PORTB.0, PORTB.1, 1, [myArray\24]
    It should shift out:
    111111110111111100000001
    MSB first right? Because something isn't right...
    If I do this:
    myLong VAR LONG
    myLong.BYTE0 = 1
    myLong.BYTE1 = 127
    myLong.BYTE2 = 255
    SHIFTOUT PORTB.0, PORTB.1, 1, [myLong\24]
    Everything seems to work as expected.
    Do I need to load my array bytes "upside down" perhaps?
    myArray[0] = 255
    myArray[1] = 127
    myArray[2] = 1
    This is all on a 18F4550 which is working quite well. I'd love to avoid LONGs if I can save a byte here and there and I'd like to stay away from putting multiple variables in my shiftout to keep my code terse. I can't post more than the pseudo code because I don't have it with me, but I figured a thought about my code during lunch hour would be an effective use of my free time.
    Thanks for any and all help as always!
    Ryan
    Default Re: A little help with shifting out Arrays?
    It shifts out each byte in the array MSB first - not the whole array MSB first. myArray[0] MSB first, then myArray[1] MSB first and so on.
    Loading the array "backwards" should do the trick I think.
    When you do the SHIFTOUT with the LONG, are you sure that it doesn't start at the most significant bit of the variable (myLong.31)?
    I would, for sure, have expected it start at the most significant bit of that 32bit variable and then shiftout 24 bits "down" thus not outputting the least significant byte. Not start in the middle of the variable....
    May 2006
    Del Rio, TX, USA
    Henrik,
    The "\bits" option shifts out the low order bits, regardless of the mode.
    May 2006
    Del Rio, TX, USA
    Ryan,
    I’m curious about the actual results you get with your example:
    myArray VAR BYTE[3]
    Why? Because PBP is not aware of, and never tracks, the array size. In fact, it isn’t an array in the same sense that other languages use arrays (like VBA or .Net). PBP only knows that MyArray[0] is a byte at address $XX. It then ‘skips’ the number of addresses you specify in your array declaration before allocating another variable to a memory location. When you use brackets, it is really only offsetting [y] from $XX. Take this example:
    myArray VAR WORD[4]
    myArray[5] = 123
    This is a perfectly valid expression, but will result in a lot of grief. What PBP will do is insert 123 into the two byte “WORD” located at a 5 WORD offset (10 bytes) from the memory location of myArray[0]. More than likely, that address will be allocated to another variable, so that variable will be corrupted, and your program will go off into a ditch pretty quick.
    So back to your problem. When you use that shift out with myArray assigned, it really only understands that myArray is a Byte. Thus, I suspect it is trying to shift out 24 bits of data, but doing so in byte sized chunks. In doing this, it’s starting with the Address of myArray[0], just as Henrick states, and moving to the next address until 24 bits are sent.
    But, I could be off track here, so I’m interested in what it’s outputting.
    Steve,
    Ha, you're right, it even says that in the manual. However, and I guess I could try this, but are you (and the manual) saying that when using "\bits" it always shifts out LSB first? The manual really isn't clear as it just says it's the low order bits regardless of the MODE but it doesn't really say if it completely disregards the MODE and does LSB first even if told to do MSB.
    I guess, based on Ryans post, that it does shift them out in the correct order, ie \24 on a long will start at the MSB of the third byte and go "down" to the LSB of the first byte.
    As for Ryans array example I'd expect the output to be 00000001 01111111 11111111. The first bit going out is the MSB of myArray[0] and the last bit going out is the LSB of myArray[2].
    Sep 2006
    Indiana, USA
    I'll maybe try both ways and break out my logic analyzer. I get confused with the MSB/LSB stuff though. I guess the analyzer captures on the screen the first bit it sees on the left hand side of the screen and goes from there. So we'll see. I just have to think about what numbers to use to get a result I can fit my little brain around. high voltage modulators and vacuum tubes at work to microcontrollers and digital circuits at home. Maybe I should take up wood working as a hobby instead!
