Reading sensors with 3.3v(beginner)
Results 1 to 18 of 18
    Default Re: Reading sensors with 3.3v(beginner)
    If you are concerned with the USB module in the18F4550 not working with Vin=3.3V, there is a way to make the module work at 3.3V.
    USB signals are 3.3 already....
    tacbanon,
    Are the remaining sensors analog or I2C, or...
    Jun 2011
    Philippines
    tacbanon,
    Not really concern with the USB part as of now...
    Sensors and modules:
    Barometric - SPI
    Ambient - Analog - (Done)
    Temp (DS18B20) - Digital
    Battery monitoring - Analog (Done)
    Accelerometer - Analog
    RTC - I2C (Done)
    SDCard - SPI (Done)
    I will try to look for an I2C accelerometer sensor if this will be easier...but it will take me another few days to get one. I have the ambient and Battery monitoring working. I also have an RTC and SDCARD on board running for data recording...
    Thanks for the time helping.
    /tacbanon
    Miami, Florida USA
    tacbanon,
    Most people use this setup to make the USB module work
    http://www.mecanique.co.uk/products/...atic-large.gif
    with Vcc = 5V. What I meant is that it can be done with Vcc = 3.3V.
    Anonymous
    Jun 2011
    Philippines
    I powered the accelerometer with a 3.3v with common ground to the PIC and read from its output pins (xyz) and here is the result.
    I noticed that even if I rotate the module in any directions, the values are much like the same...
    /tacbanon
    What do you read if you connect a volt meter in-place of a PIC on the outputs of the ADXL335?
    Jun 2011
    Philippines
    When reading with voltmeter varies on x,y and z pin (between 0 - 3.4v) when rotating the module.
    /tacbanon
    Hmmm,
    The module is working.
    You know how to use the ADC.
    I guess we will have to see your code to spot the problem...
    Jun 2011
    Philippines
    Hmmm,
    Hi, thanks for your time. Thought it is best if I give a little description to what I'm trying to achieve. I'm setting 3 buttons to navigate to some menus to display information for the accelerometer, ambient, Temp, Barometric pressure, battery level, RTC, GPS and GSM and Bluetooth connectivity on the 4x20 LCD. SdCard is used for data logging later on.
    My codes mostly came from this forum(thanks to u all!), BTW currently I'm using the hyper terminal to navigate thru the menus...so here it is.
    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    DEFINE OSC 48
    DEFINE HSER_RCSTA 90h ' enable serial port,
    DEFINE HSER_TXSTA 20h  ' enable transmit,
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLOERR  1 ' automatic clear overrun error
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ' Include if using PBP interrupts
        '   Variable definition
    PortB = %00000000
    TRISB = %00000000
    TRISC  = %10000000    ' PORTC.7 is the RX input, PORTC.6 is the TX output
    RCIF       VAR     PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
    TXIF       VAR     PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
    led        var     PORTD.5
    StatusLed        var     PORTD.6
    StatusLed1        var     PORTD.7
    holdoff    var     word
    SerialData var     byte
    SerialInput var    byte[50]
    PortB = 0
    c var byte  'counter1
    cnt  var byte 'counter2
    cnt1  var byte 'counter3
    cnt1=0
    i var byte
    c = 0
    OptionSel var byte[1]
    OptionSel  = "0"
    flag1 var byte
    flag1 = 0
    'clear
            INT_Handler   RX_INT,    _Getbytes,    PBP,  no
    @   INT_ENABLE  RX_INT     ; enable RX_INT interrupts
    '*******Internal interrupt
    T1CON = $31               ; Prescaler = 8, TMR1ON
    '***LCD Definitions
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    ' Alias PIC pins and registers for SD/MMC card
    SD_WE		Var	PORTA.7	' SD card write protect  A4
    SD_WE_TRIS	Var	TRISA.7	' SD card write protect direction
    SDI		Var	PORTC.1	' SPI data in  PORTB.0
    SDI_TRIS	Var	TRISC.1	' SPI data in direction TRISB.0
    SCL		Var	PORTC.2	' SPI clock  PORTB.1
    SCL_TRIS	Var	TRISC.2	' SPI clock direction  TRISB.1
    SD_CS		Var	PORTC.3	' SD card chip select    PORTB.3
    SD_CS_TRIS	Var	TRISC.3	' SD card chip select direction TRISB.3
    SD_CD		Var	PORTB.6	' SD card detect  PORTB.4
    SD_CD_TRIS	Var	TRISB.6	' SD card detect direction  TRISB.4
    SDO		Var	PORTC.0	' SPI data out
    SDO_TRIS	Var	TRISC.0	' SPI data out direction
        Include "SDFS.PBP"
        ;SDC_UseHardSPI = TRUE    ' Use hardware SSP port for SPI.
        SDC_UseHardSPI = FALSE    ' Use hardware SSP port for SPI.
        'ADCON1 = 15        ' All I/O pins digital
        '--Added Pic settings
        UCON.3 = 0        'USB module disabled
        UCFG.3 = 1        'USB transceiver disabled
        CCP1CON=0       '  Capture/Compare OFF
        CCP2CON=0       '
        Pause 100
    ;--For ADC modules
    define ADC_BITS  8
    define ADC_CLOCK 3
    define ADC_SAMPLEUS 50
    ambval var byte
    batval var byte
    axval var byte
    ayval var byte
    azval var byte
    TRISA  = %00111111
    ADCON1 = %00001001
    ' FSInit initializes the card and reads all the preliminary information from it
        Gosub FSInit
        Hserout ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
        If (FAT_error != 0) Then Stop
    ' This section defines a specific short (8.3) filename
    '  Note that spaces are use in empty elements and must be upper case for Windows
        FAT_FileName[0] = "R"
        FAT_FileName[1] = "E"
        FAT_FileName[2] = "C"
        FAT_FileName[3] = "O"
        FAT_FileName[4] = "R"
        FAT_FileName[5] = "D"
        FAT_FileName[6] = "S"
        FAT_FileName[7] = " "
        FAT_FileName[8] = "T"
        FAT_FileName[9] = "X"
        FAT_FileName[10] = "T"
    ' Set file time to 8:30:10 and date to 1/1/2008
        FAT_seconds = 5
        FAT_minutes = 30
        FAT_hours = 8
        FAT_day = 1
        FAT_month = 1
        FAT_year = 28
    ;-------------------------RTC--------------------------------------------------
    'RTC pins on 4550
    SDA	Var	PORTB.6
    SCLA	Var	PORTB.7
    'Try to change
    ;Led1 var PortB.2
    ' Allocate variables
    RTCYear	Var	Byte
    RTCMonth Var Byte
    RTCDate	Var	Byte
    RTCDay	Var	Byte
    RTCHour	Var	Byte
    RTCMin	Var	Byte
    RTCSec	Var	Byte
    RTCCtrl Var	Byte
    SEC_O VAR BYTE: SEC_T VAR BYTE:
    MIN_O VAR BYTE: MIN_T VAR BYTE
    HR_O VAR BYTE:  HR_T VAR BYTE:
    MON_O VAR BYTE: MON_T VAR BYTE
    DATE_O VAR BYTE: DATE_T VAR BYTE:
    DAY_O VAR BYTE: DAY_T VAR BYTE:
    YR_O VAR BYTE: YR_T VAR BYTE
    CMCON = %00000111                   ' Comparators = off
     '--------------------------Custom characters
       LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250
       LCDOUT  $FE,$40,$1F,$15,$11,$11,$15,$15,$15,$1F  ' Cust Char #0
       LCDOUT  $FE,$48,$1F,$1F,$1F,$11,$15,$15,$11,$1F  ' Cust Char #1
       LCDOUT  $FE,$50,$1F,$17,$17,$11,$15,$15,$11,$1F  ' Cust Char #2
       LCDOUT  $FE,$58,$1F,$1F,$1F,$11,$15,$15,$11,$1F  ' Cust Char #3
       LCDOUT  $FE,$60,$1F,$1B,$1B,$11,$1B,$1B,$19,$1F  ' Cust Char #4
       LCDOUT  $FE,$68,$1F,$1F,$1F,$1F,$1F,$1F,$1F,$1F  ' Cust Char #5
       LCDOUT  $FE,$70,$1F,$1F,$1F,$15,$15,$15,$1B,$1F  ' Cust Char #6
       LCDOUT  $FE,$78,$1F,$13,$1B,$1B,$1B,$1B,$11,$1F  ' Cust Char #7
       pause 300
    ' Initialize LCD
    ;LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250
     'Set initial time                                                    `
    	RTCYear = $12
    	RTCMonth = $09
    	RTCDate = $20
    	RTCDay = $18
    	RTCHour = $21
    	RTCMin = $55
    	RTCSec = 0
    	RTCCtrl = 0
     goto mainloop
    ' Subroutine to write time to RTC
    set:
    I2CWrite SDA,SCLA,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCDay,RTCDate,RTCMonth,RTCYear,RTCCtrl]
    ' Subroutine to read time from RTC
    gettime:
    	I2CRead SDA,SCLA,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCDay,RTCDate,RTCMonth,RTCYear,RTCCtrl]
    	; we prepare this for later use
    	SEC_T = RTCSec & $70
        SEC_T = SEC_T>>4
        SEC_O = RTCSec & $0F
        MIN_T = RTCMin & $70
        MIN_T = MIN_T>>4
        MIN_O = RTCMin & $0F
        HR_T = RTCHour & $70
        HR_T = HR_T>>4
        HR_O = RTCHour & $0F
        MON_T = RTCMonth & $70
        MON_T = MON_T>>4
        MON_O = RTCMonth & $0F
        DATE_T = RTCDate & $70
        DATE_T = DATE_T>>4
        DATE_O = RTCDate & $0F
        DAY_T = RTCDay & $70
        DAY_T = DAY_T>>4
        DAY_O = RTCDay & $0F
        YR_T = RTCYear & $70
        YR_T = YR_T>>4
        YR_O = RTCYear & $0F
        ' Open a file for write
        FAT_mode = "a"        ' Write mode
        Gosub FSfopen        ' Open file pointed to by Byte array FAT_FileName
        hserout ["Open for write: ", Dec FAT_error, $d, $a]
        FAT_src[0] = ">"
        FAT_src[1] = "T"
        FAT_src[2] = "E"
        FAT_src[3] = "S"
        FAT_src[4] = "T"
        FAT_src[5] = "D"
        FAT_src[6] = "A"
        FAT_src[7] = "T"
        FAT_src[8] = "A"
        FAT_src[9] = 13
        FAT_src[10] = 10
        FAT_count = 11
        Gosub FSfwrite
        hserout [ "Write ", Dec FAT_error, $d, $a]
    ' Close file
        Gosub FSfclose
        hserout [ "Close ", Dec FAT_error, $d, $a]
    mainloop:
    	'Gosub gettime		' Read the time from the RTC
          c = 0 ' counter
          Select case OptionSel
          case "0"
          gosub page0
          case "1"
          gosub page1
          case "2"
          gosub page2
          case "3"
          gosub page3
          case "4"
          gosub page4
          case "5"
          gosub page5
          case "6"
          gosub page6
          End select
    	Goto mainloop
               'ISR for RX_int interrupt
    Getbytes:
           While RCIF = 1     ' clear the buffer
           c = c + 1
           HSERIN 100,error,[Serialdata] ' take it
           '--HSEROUT [Serialdata] ' take it out
           SerialInput[c] = Serialdata
           LCDOUT
           select case Serialdata          ' What to do with that data???
           case "0"
             Hserout ["Option 0",13]
             OptionSel = "0"
             flag1 = 0
           case "1"
            Hserout ["Option 1",13]
            OptionSel = "1"
            flag1 = 0
           case "2"
            Hserout ["Option 2",13]
            OptionSel = "2"
            flag1 = 0
           case "3"
            Hserout ["Option 3",13]
            OptionSel = "3"
            flag1 = 0
           case "4"
            Hserout ["Option 4",13]
            OptionSel = "4"
            flag1 = 0
           case "5"
            Hserout ["Option 5",13]
            OptionSel = "5"
            flag1 = 0
           case "6"
            OptionSel = "6"
            flag1 = 0
           End select
           Wend
    @ INT_RETURN
    error:
          Toggle led
    @ INT_RETURN
     ' We try to place the module reading process here
    ToggleLED1:
    cnt = cnt + 1
    if cnt = 10 then
         TOGGLE StatusLed   ' slower process
    cnt = 0
    Endif
    cnt1 = cnt1 + 1
    if cnt1 = 5 then
         TOGGLE StatusLed1  ' faster process
         ADCIN 0, ambval
         ADCIN 1, batval
         ADCIN 2, axval
         ADCIN 3, ayval
         ADCIN 5, azval
         hserout ["Light ", DEC ambval," Bat ", Dec batval, " X: ",Dec axval," Y: ",Dec ayval," Z: ",Dec azval, 13] ' just to see it on the hyperterminal
    cnt1 = 0
    Endif
    @ INT_RETURN
    page0:
       if flag1 < 1 then
       gosub LcdClear
       flag1 = flag1+1
       LCDOUT $fe,$80,0,1,2,3,4,5,6,7,5,5,5,5,5,5,5,5,5,"[1]"
       LCDOUT $fe, $C0, "School Demo"
       LCDOUT $fe, $94, "Designer: Tacbanon"
       LCDOUT $fe, $D4, "Command: "
       PAUSE 100
    page1:
       if flag1 < 1 then
       gosub LcdClear
       flag1 = flag1+1
       LCDOUT $fe, $80, "RTC and BAT",5,5,5,5,5,5,"[2]" ' Display PULSVARs
       LCDOUT $fe, $C0, "Date:",HEX DATE_T, Hex DATE_O,"/",Hex MON_T,Hex MON_O,"/",Hex YR_T, Hex YR_O
       LCDOUT $fe, $94, "Time:",hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec
       LCDOUT $fe, $D4, "Bat1:       "
       LCDOUT $fe, $D4, "Bat1: ", Dec batval
       Pause 50
    page2:
      if flag1 < 2 then
       gosub LcdClear
       flag1 = flag1+1
       LCDOUT $fe, $80, "ACCELEROMETER",5,5,5,5,"[3]"
       LCDOUT $fe, $C0, "x: ",Dec axval
       LCDOUT $fe, $94, "y: ",Dec ayval
       LCDOUT $fe, $D4, "z: ",Dec azval
       PAUSE 50
    page3:
       if flag1 < 2 then
       gosub LcdClear
       flag1 = flag1+1
       LCDOUT $fe, $80, "MISC SENSORS",5,5,5,5,5,"[4]"
       LCDOUT $fe, $C0, "Temp: "
       LCDOUT $fe, $94, "Amb:        "
       LCDOUT $fe, $94, "Amb:  ",Dec ambval
       LCDOUT $fe, $D4, "Bmtr: "
       PAUSE 50
    page4:
       if flag1 < 2 then
       gosub LcdClear
       flag1 = flag1+1
       LCDOUT $fe, $80, "POSITIONING",5,5,5,5,5,5,"[5]"
       LCDOUT $fe, $C0, "Lat: "
       LCDOUT $fe, $94, "Lng:  "
       LCDOUT $fe, $D4, "Knot: "
       PAUSE 50
    page5:
       if flag1 < 2 then
       gosub LcdClear
       flag1 = flag1+1
       'LCDout $Fe, 1
       LCDOUT $fe, $80, "GSM and BT",5,5,5,5,5,5,5,"[6]"
       LCDOUT $fe, $C0, "Man: "
       LCDOUT $fe, $94, "Sig:  "
       LCDOUT $fe, $D4, "BT stat: "
       PAUSE 50
    page6:
       if flag1 < 2 then
       gosub LcdClear
       flag1 = flag1+1
       LCDOUT $fe, $80, "SDCARD Info",5,5,5,5,5,5,"[7]"
       LCDOUT $fe, $C0, "No. write: "
       LCDOUT $fe, $94, "No. dump:  "
       LCDOUT $fe, $D4, "Status: "
       PAUSE 50
    LcdClear: ' clear LCD
    LCDOUT $fe, $80, "                    "
    LCDOUT $fe, $C0, "                    "
    LCDOUT $fe, $94, "                    "
    LCDOUT $fe, $D4, "                    "
    pause 400
    /tacbanon
