Reading sensors with 3.3v(beginner)
Results 1 to 18 of 18
    Jun 2011
    Philippines
    Default Re: Reading sensors with 3.3v(beginner)
    Hello Dave and rsocor01, I think among the sensors (accelerometer, ambient, barometric, temperature and 5v battery) I'm planning to incorporate, the accelerometer is only the one that have 3.3v...that is why I tend to use the 5v source...any input is much appreciated on how to approach this.
    Kind regards,
    tacbanon
    If you are concerned with the USB module in the18F4550 not working with Vin=3.3V, there is a way to make the module work at 3.3V.
    USB signals are 3.3 already....
    tacbanon,
    Are the remaining sensors analog or I2C, or...
    Jun 2011
    Philippines
    tacbanon,
    Not really concern with the USB part as of now...
    Sensors and modules:
    Barometric - SPI
    Ambient - Analog - (Done)
    Temp (DS18B20) - Digital
    Battery monitoring - Analog (Done)
    Accelerometer - Analog
    RTC - I2C (Done)
    SDCard - SPI (Done)
    I will try to look for an I2C accelerometer sensor if this will be easier...but it will take me another few days to get one. I have the ambient and Battery monitoring working. I also have an RTC and SDCARD on board running for data recording...
    Thanks for the time helping.
    /tacbanon
    Miami, Florida USA
    tacbanon,
    Most people use this setup to make the USB module work
    http://www.mecanique.co.uk/products/...atic-large.gif
    with Vcc = 5V. What I meant is that it can be done with Vcc = 3.3V.
    Anonymous
    Jun 2011
    Philippines
    I powered the accelerometer with a 3.3v with common ground to the PIC and read from its output pins (xyz) and here is the result.
    I noticed that even if I rotate the module in any directions, the values are much like the same...
    /tacbanon
    What do you read if you connect a volt meter in-place of a PIC on the outputs of the ADXL335?
    Jun 2011
    Philippines
    When reading with voltmeter varies on x,y and z pin (between 0 - 3.4v) when rotating the module.
    /tacbanon
    Hmmm,
    The module is working.
    You know how to use the ADC.
    I guess we will have to see your code to spot the problem...
