Yes, but you may want to set the ADC reference voltage to 3.3.
But why not just run the 18F4550 at 3.3?
Yes, you can run the 18F4550 at 3.3V like Dave said. If you are concerned with the USB module in the18F4550 not working with Vin=3.3V, there is a way to make the module work at 3.3V.
Anonymous
Hello Dave and rsocor01, I think among the sensors (accelerometer, ambient, barometric, temperature and 5v battery) I'm planning to incorporate, the accelerometer is only the one that have 3.3v...that is why I tend to use the 5v source...any input is much appreciated on how to approach this.
Kind regards,
tacbanon
USB signals are 3.3 already....If you are concerned with the USB module in the18F4550 not working with Vin=3.3V, there is a way to make the module work at 3.3V.
tacbanon,
Are the remaining sensors analog or I2C, or...
Not really concern with the USB part as of now...
Sensors and modules:
Barometric - SPI
Ambient - Analog - (Done)
Temp (DS18B20) - Digital
Battery monitoring - Analog (Done)
Accelerometer - Analog
RTC - I2C (Done)
SDCard - SPI (Done)
I will try to look for an I2C accelerometer sensor if this will be easier...but it will take me another few days to get one. I have the ambient and Battery monitoring working. I also have an RTC and SDCARD on board running for data recording...
Thanks for the time helping.
/tacbanon
Most people use this setup to make the USB module work
http://www.mecanique.co.uk/products/...atic-large.gif
with Vcc = 5V. What I meant is that it can be done with Vcc = 3.3V.
Anonymous
I powered the accelerometer with a 3.3v with common ground to the PIC and read from its output pins (xyz) and here is the result.
I noticed that even if I rotate the module in any directions, the values are much like the same...
/tacbanon
What do you read if you connect a volt meter in-place of a PIC on the outputs of the ADXL335?
