How do you do this in Assembly
Results 1 to 4 of 4
    ice's Avatar
    ice Guest
    Default How do you do this in Assembly
    Hello..
    i'm trying to port the "quadrature decoding" program to assembly.
    The original thread is over here.
    I'm running into a few problems
    1>
    coverting "new=PORTB & %11000000" to assembly
    movf	PORTB,W
                             ANDLW	11000000   ;take in portB ,and with 11000000 and store in "W"
    		movwf	_new	   ;load into "new" variable
    The statement ANDLW 11000000 in assembly is written as ANDLW b'11000000'
    However it doesnt compile if i put in ANDLW b'11000000'
    2>how do i compare 2 variables "old_val = new_val" in assembly?
    Thank you
    Dec 2003
    Wichita KS
    Hello Ice,
    Ice>>Hello..i'm trying to port the "quadrature decoding" program to assembly.
    I'm running into a few problems<<
    99 percent of the folks on this forum use Pic Basic or Pic Basic Pro. Maybe Melanie, Ralph, or Mister-e may get a wild hair and tackle the problem for you, if they have time. People use PBP, so they do not have to mess with the assembly routines. One way how you can find your answer, is look at the detailed Data sheet of your PIC chip you are using. I will show you how to use assembly to assign your Ports... etc. Some data sheets will give you all 32 assembly commands. Called RISC Reduced Instruction S (forgot what the S was Set?) Code.
    Its been 15 years since I have messed with assembly...Most of it I have forgot <g>. If you have PBP, you can write the routine, and look at your (PBP MACRO-type) assembly code after a compilation. Or, you can go to compilespot, and do it for free.... Just write the very basic of what you need.
    Val1 var byte
    Val2 Var byte
    Val1=Portb
    if(Val1> Valb) goto .....
    Compile and look at the assembly.
    Realize that it is not TRUE assembly But gives a person a idea via the small subroutines or macros that PBP uses to work with Assembly.
    Here is a thread that may help:
    http://www.picbasic.co.uk/forum/show...light=assembly
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Italy
    Hi Ice,
    See new post in thread "decoding quadrature encoders".
    Luciano
    ice's Avatar
    ice Guest
    Thanks Dwayne,
    I needed the assembly as im using it for an interrrupt program for decoding encoders...
    It's a part of this thread
    http://www.picbasic.co.uk/forum/showthread.php?t=1552
    Thanks Luciano..im working on the code tday
  1. Microchip Assembly Commands
    By picnaut in forum Documentation
    Last Post: - 18th March 2011, 00:06
  2. Picbasic Pro Demo assembly errors
    By mikeRho in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 06:41
  3. Assembly Guru : Question
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 20th May 2007, 03:51
  4. from assembly to basic
    By shantanu in forum Off Topic
    Last Post: - 1st February 2007, 14:50
  5. Assembly Language + PBP
    Last Post: - 10th January 2006, 13:54
