Altering a variable in a loop.
Results 1 to 27 of 27
    Feb 2004
    Michigan, USA
    Default Re: Altering a variable in a loop.
    That's exactly it. New current level gets set, pwm is set to a beginning level at the start of the loop. After one loop the pwm is set by the feedback, ignoring the initial start level.
    Here's the basic principle of using the flag method:
    UpButton VAR PortB.0   			' Active high button
    DnButton VAR PortB.1   			' Active high button
    Setting VAR BYTE
    SettingChanged VAR BIT
    DutyCycle VAR BYTE
      If UpButton THEN
        Setting = Setting + 1              ' Increment setting
        If Setting = 6 THEN Setting = 5    ' Make sure it doesn't go beyond 5
        SettingChanged = 1                 ' Set flag indicating new setting
      EndIf
      If DnButton THEN
        Setting = Setting - 1
        If Setting = 255 THEN Setting = 0  ' Make sure it doesn't go below 0
      EndIf
      If SettingChanged THEN
        LOOKUP Setting, [12,23,34,45,56], DutyCycle
        SettingChanged = 0                 ' Clear flag
      EndIf
      ' Your regulator code here...
    Goto Main
    Aug 2012
    Comodoro Rivadavia - Patagonia Argentina
    very good your contribution! I find it very helpful to see the logic with other people who program to learn more every day... Thanks Henrik
