Altering a variable in a loop.
Results 1 to 27 of 27
    Aug 2012
    Comodoro Rivadavia - Patagonia Argentina
    Default Re: Altering a variable in a loop.
    not quite understand the idea if you're needing, but I work with a MAP for a car, what I did was to implement a hardware PWM (in the background) and a TMR0 interrupt.
    Within the interrupt, which is to read the ADC and modified the pwm ...
    With all this, I required no implementing a LOOP and my program was much more efficient
    Note: (do not know if the translation is fine >> background = the 2nd plane?)
    Aug 2012
    would fail to correct the fuses and setup the interruption, but more or less the idea was so (I have to find where I have the complete original program that works well) ... ¨ I understood correctly?
    'OPTION_REG =%00111111
    PORTA=0:TRISA=%00000001
    PORTB=0:TRISB=%00000000
    PORTC=0:TRISC=%00000000
    PORTD=0:TRISD=%00000000
    ADCON1= %10001110 '
    T2CON = %00000101
    PR2=249
    @ DEVICE PIC16F877
    @ DEVICE PIC16F877, WDT_OFF
    @ DEVICE PIC16F877, PWRT_OFF
    @ DEVICE PIC16F877, PROTECT_OFF
    @ DEVICE PIC16F877, XT_OSC
    '**** configuracion canal ADC (ADC chanel setting) ***********
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 1
    DEFINE ADC_SAMPLEUS 3
    '*********** Configuracion HPWM (HPWM PRESETING) *************
    DEFINE CCP1_REG PORTC
    DEFINE CCP1_BIT 2
    DEFINE CCP2_REG PORTC
    DEFINE CCP2_BIT 1
    HAM var word
    X VAR WORD
    DUTY VAR BYTE
    CCP1CON.2=1
    CCP1CON.3=1
       On Interrupt Goto int_TIMER0
       INTCON = %10100000
    Menu:
    DUTY=50
    GOSUB salida
    GOTO Menu
    salida:
    PR2=((1024-HAM)*/5625)/100+24
    X=(PR2+1)* DUTY /25
    CCP1CON.4=X.0
    CCP1CON.5=X.1
    CCPR1L=x>>2
    Disable
    int_TIMER0:
    ADCIN 0,HAM
    INTCON = %10100000
    Resume
    Enable
    regards
    jmgelba,
    The key is to only execute the lookup (or other) code once each time you actually CHANGE the setting - not all the time. If you insist on having it inside a big loop you need a flag to indicate that the setting has changed and that the dutycycle needs to be reset to a new base value.
    Feb 2004
    Michigan, USA
    That's exactly it. New current level gets set, pwm is set to a beginning level at the start of the loop. After one loop the pwm is set by the feedback, ignoring the initial start level.
    Here's the basic principle of using the flag method:
    UpButton VAR PortB.0   			' Active high button
    DnButton VAR PortB.1   			' Active high button
    Setting VAR BYTE
    SettingChanged VAR BIT
    DutyCycle VAR BYTE
      If UpButton THEN
        Setting = Setting + 1              ' Increment setting
        If Setting = 6 THEN Setting = 5    ' Make sure it doesn't go beyond 5
        SettingChanged = 1                 ' Set flag indicating new setting
      EndIf
      If DnButton THEN
        Setting = Setting - 1
        If Setting = 255 THEN Setting = 0  ' Make sure it doesn't go below 0
      EndIf
      If SettingChanged THEN
        LOOKUP Setting, [12,23,34,45,56], DutyCycle
        SettingChanged = 0                 ' Clear flag
      EndIf
      ' Your regulator code here...
    Goto Main
    Aug 2012
    very good your contribution! I find it very helpful to see the logic with other people who program to learn more every day... Thanks Henrik
