Timer 0 in DS_int_14 having a problem
Results 1 to 11 of 11
    Feb 2012
    PERTH AUSTRALIA
    Wink Re: Timer 0 in DS_int_14 having a problem
    thanks Hendrick , i did not follow what he ment by the comment
    I eventually found that code
     if (T0Count = Smoothfade) and Fade_flag = 2 then Smooth_reset
    was not returning , thought it was acted upon the same as
     if (T0Count = Smoothfade) and Fade_flag = 2 then gosub Smooth_reset
    but it is not , as you say , the first is a goto and 2nd statement with the " gosub" returns and works fine
    Well something i did not know, i know now
    More fun learning ahead
    Cheers
    sheldon
    Default Re: Timer 0 in DS_int_14 having a problem
    Yeah, a subroutine must always end with a RETURN and must always be jumped to with a GOSUB.
    If you GOTO a subroutine it will fail badly once it hits the RETURN statement because it will then "return" to the wrong place because the correct place hasn't been stored.
    * Never GOSUB anything not ending with RETURN.
    * Never GOTO anything which does end with RETURN.
    The manual is pretty clear on that specifying a label in an IF statement causes a GOTO when the expression is evaluated true.
    I'm glad you're moving forward!
