Question on SPI Data out on PortC.7(pic18f4550)
Results 1 to 10 of 10
    Jun 2011
    Philippines
    Default Re: Question on SPI Data out on PortC.7(pic18f4550)
    Hello macrackit, I will check it out..thanks.
    Kind regards,
    tacbanon
    Jun 2011
    Philippines
    I'm trying to figure it out this block of code from SDFS how to make disable hardware SPI.
    ' Initialize some values for the following subroutines
    	SDC_UseHardSPI = TRUE	' Use hardware SSP port for SPI.
    	DISK_mount = FALSE	' The card has not been initialized.
    	FAT_mode = "r"		' Read mode if not otherwise specified.
    	FAT_count = 0		' Default character count to 0.
    ' Skip over SD/MMC/FAT subroutines
    	Goto SkipSD
    ' Subroutines for communicating with an SD/MMC card
    ' Subroutine to initialize SD card pins
    InitIO:
    	SD_CS = 1		' SD card not selected.
    	SD_CS_TRIS = 0		' Output SD card chip select.
    	SD_CD_TRIS = 1		' Input card detect.
    	SDO = 1			' Start SPI data out high.
    	SDO_TRIS = 0		' Output SPI data out.
    	SDI_TRIS = 1		' Input SPI data in.
    	SCL = 1			' SPI clock idles high.
    	SCL_TRIS = 0		' Output SPI clock.
    ' Subroutine to initialize hardware SSP for SPI at less than 400kHz
    OpenSPIM:
    	If (SDC_UseHardSPI) Then
    		SSPSTAT = %00000000	' Sample at middle of data output time, Mode 1, 1: Transmit on idle to active clock transition.
    		SSPCON1 = %00010010	' SPI master mode, clock = Fosc/64, Mode 1, 1: Clock idle high.
    		SSPEN = 1		' Enable hardware SPI port.
    	Endif
    ' Subroutine to initialize hardware SSP for SPI at full speed
    OpenSPIMFast:
    		SSPCON1 = %00010000	' SPI master mode, clock = Fosc/64, Mode 1, 1: Clock idle high.
    	Endif
    ' Subroutine to release hardware SSP from SPI
    CloseSPIM:
    		SSPEN = 0		' Disable hardware SPI port.
    	Endif
    But not really sure what to do? Hope anyone can help out...
    /tacbanon
    I've never used that code but I'd probably try SDC_UseHardwareSPI = FALSE.
    However, don't change the SDFS.pbp file. INCLUDE it in your program and ADD SDC_UseHardwareSPI = FALSE after including it (see the example) - it will "overwrite" the default setting.
    Jun 2011
    Philippines
    Hi Henrik,
    Thanks for the response, I will try it and post here my result.
    Kind regards,
    tacbanon
    /Henrik is correct.
    This example may help.
    http://www.picbasic.co.uk/forum/cont...USB-SD-LOGGING
    I did comment out the pin alias in SDFS so I could change things around in my code without bothering with opening the include.
    Jun 2011
    Philippines
    @Dave
    Sorry for the late reply...thanks for the link..got it to work now.
    /tacbanon
