NTP server / External (no "www") time base for PC / DCF77
Results 1 to 13 of 13
    SWITZERLAND (french speaking)
    Default NTP server / External (no "www") time base for PC / DCF77
    Hi there,
    I have built a DCF77 receiver (http://www.ptb.de/en/org/4/44/442/dcf77_1_e.htm) I'd like to use as a time base server in a "private" LAN (= no connection to www).
    As my programming skills are modest, I don't know how to create a NTP software. All I could reach, is a simple DELPHI based tool that will update the PC's internal clock via TIME and DATE DOS commands. I grab the receiver's data via the COM port.
    I had a look at this kind of module http://www.connectone.com/products.asp?did=73&pid=93 that might be of any help. But what about the sofware?
    Roger
    Boston MA
    NTP on port 123 is going to be a LOT to work on. If you have needs for VERY high accuracy it's what you use. Commercial NTP time servers are in the $2K range See:
    http://www.ntp.org/
    SNTP is easier to deal with (this is what your PC uses to sync up)
    http://www.micro-examples.com/public...nal-clock.html (the code for this is over 1K lines)
    Time Server on port 37 is easier
    http://www.codeproject.com/KB/IP/udptime.aspx
    DayTime server on port 13 is even simpler
    I would start your efforts programming a Time Server client using a PIC ENC28J60. Once you get a little background and practice start working on the server.
    As far a I know no big company ever made a 60/77khz NTP server. There is too much phase shift every day. Most people use GPS as a source for an NTP server. However a 77Khz time source would make a good backup.
    I expect to work on such a project down the road but I will probably use something with a little more power like an Ethernut http://www.ethernut.de/en/index.html They have an example of a SNTP client that is less than 200 lines but written in C code.
    Tim
    Sep 2005
    Campbell, CA
    I wrote a routine that 'calls' a timeserver on port 123 (UDP protocol). It uses a Lantronix XPort as the network interface.
    The routine calculates current time based on NET TIME (number of seconds elapsed since 00:00:00,Jan 1, 1900). It allows input of time zone and DST flag. It doesn't automatically calculate when DST begins/ends, but it does take DST into account. Leap years, too.
    It shows the current time and then writes the values into a DS1307.
    If someone is interested, I'll post.
    Charles Linquist
    Aug 2008
    Portugal
    Quote Originally Posted by Charles Linquis View Post
    Hi, i'm interested in your project. Can you post the code, please?
    Thanks and Regards;
    Gadelhas
    Sep 2005
    Campbell, CA
    It might take a bit of explanation, but -
    The code below is sent after the XPort is initialized for UDP.
    Hoffset is number of hours before or after GMT.
    SIGN is earlier ("1") or later ("2") than GMT.
    The code works only with 18F chips because it uses PBPL.
    GETNETTIME:
           NETRETRYCOUNT = 0
           GOSUB INTDISABLE
    GETNETTIME2:
           HSEROUT [13,10,"TIMESERVER ",#TSIP1,".",#TSIP2,".",#TSIP3,".",#TSIP4,13,10]
           PAUSE 100
            THEADER[0] = $2           ' STX
            THEADER[1] = TSIP1  ' DESTINATION IP
            THEADER[2] = TSIP2
            THEADER[3] = TSIP3
            THEADER[4] = TSIP4
            THEADER[5] = 0            ; DESTINATION PORT HIGHBYTE
            THEADER[6] = 123          ; DESTINATION PORT LOWBYTE
            LRC1 = 0
            LRC2 = 0
            For X = 1 to 6
                 LRC1 = LRC1 ^ THeader[x]
            next X
            THEADER[7] = LRC1
            THEADER[8] = 0
            THEADER[9] = 48                                             'Data Length lowbyte
    ;Send the header
              HSEROUT [13,10]
              For X = 0 to 9
                HSEROUT2 [THeader[X]]
              Next X
              LRC2 = LRC2 ^ THeader[8]
              LRC2 = LRC2 ^ THeader[9]
    ;Send the data
              HSEROUT2 [$1B]
               LRC2 = LRC2 ^ $1B
              For X = 0 To 46
                HSEROUT2 [0]
                LRC2 = LRC2 ^ 0
              NEXT X
    ;Send the Checksum (LRC)
              HSEROUT2 [LRC2]
    getresponse:
             HSERIN2 1000,NoResponse,[Wait($2)]
             hserin2 200,NoResponse,[SKIP 41,TimeNow.Byte3,TimeNow.Byte2,TimeNow.Byte1,TimeNow.Byte0]
    '             TIME1900_2009 = 3439756800
              READ 851,HOFFSET
                   IF sign = "1" then
                      if DST = 1 and HOffset = 0 THEN
                           Sign = "2"
                           GOTO OtherSide
                         TimeNow = Timenow - ((HOffset - DST) * 3600)
    OtherSide:
                   IF Sign = "2" THEN
                      TimeNow = TimeNow + ((Hoffset + DST) * 3600)
                    SINCEJAN2009 = TIMENOW - 3439756800   ; 3439756800 is the #of sec from Jan1 1900 to Jan1 2009
                    RUNNINGSECONDS = SINCEjAN2009
                    YR = 2009
    GETYEAR:
                        LEAP = (YR//4)    ; = 0 if leap year
                        if LEAP = 0 then
                            SecondsInYear = 31622400 ;366*60*60**24
                            SecondsInYear = 31536000 ;365*60*60*24
                        If RunningSeconds > SecondsInYear Then
                            RunningSeconds = RunningSeconds - SecondsInyear
                            YR = YR + 1
                            GOTO GetYear
                     Mo = 1 ; Start with Month = 1
    GETMONTH:
                    IF LEAP > 0 THEN
                       lookup2 MO,[0,2678400,2419200,2678400,2592000,2678400,2592000,2678400,2678400,2592000,2678400,2592000,2678400],SecondsInMonth
                       LOOKUP2 MO,[0,2678400,2505600,2678400,2592000,2678400,2592000,2678400,2678400,2592000,2678400,2592000,2678400],SecondsInMonth
                    If RunningSeconds >= SecondsInMonth THEN
                       RunningSeconds = RunningSeconds - SecondsInMonth
                    MO = MO + 1
                    GOTO GETMONTH
    FINDDAYS:
                    DA = RUNNINGSECONDS/86400
                    RUNNINGSECONDS = RUNNINGSECONDS//86400
                    HR = RUNNINGSECONDS/3600
                    RUNNINGSECONDS = RUNNINGSECONDS//3600
                    MN = RUNNINGSECONDS/60
                    RUNNINGSECONDS = RUNNINGSECONDS//60
                    SC = RUNNINGSECONDS
                    Da = Da + 1   ; Because there is no day zero
                   HSEROUT [13,10,13,10,DEC2 HR,":",DEC2 MN,":",DEC2 SC,"   ",DEC2 MO,"/",DEC2 DA,"/",#YR,13,10]
                   YR8 = YR - 2000 ; clock only takes two digits!
    ConverttoBCD:
                   DT = (DA/10) << 4 + (DA//10)
                   YR8 = (YR8/10) << 4 + (YR8//10)
                   MN = (MN/10) << 4 + (MN//10)
                   SC = (SC/10) << 4 + (SC//10)
                   HR = (HR/10) << 4 + (HR//10)
                   MO = (MO/10) << 4 + (MO//10)
                   gosub CLOCKWRITE
                   NetFail = 0
                   HSEROUT ["CLK updated",13,10]
                    pause 2000
                  goto DoneClock
    NoResponse:
                   hserout ["RETRYING GetNetTime",13,10]
                     NETRETRYCOUNT = NETRETRYCOUNT + 1
                     if NETRETRYCOUNT < 5 THEN
                        goto getnettime2
                     IF NETRETRYCOUNT < 10 THEN
                        GOSUB GETALTERNATESERVER
                        goto getnettime2
                        READ 800,Dummy
                        TSIP1 = Dummy
                        THEADER[1] = TSIP1  'Set it back to primary
                        READ 801,Dummy
                        TSIP2 = Dummy
                        THEADER[2] = TSIP2
                        READ 802,Dummy
                        TSIP3 = Dummy
                        THEADER[3] = TSIP3
                        READ 803,Dummy
                        TSIP4 = Dummy
                        THEADER[4] = TSIP4
                        NetFail = 1
                     HSEROUT [13,10,"FAILED NET TIME",13,10]
    DoneClock:
             GOSUB INTREENABLE
    Charles Linquist
    Dec 2005
    Thumbs up
    Thanks, Charles. I've been planning to write a similar procedure although I 'm using a different ethernet adapter (WIZ110SR), different RTC (ST M41T81) and different processor (ZBasic ZX40p). Still, adapting your code should save me a lot of time and error.
    BTW, I've also used the ConnectOne nano LanReach mentioned by the OP. It has a very attractive price, easy communication protocol (patterned after modem AT commands) and a nice set of Internet protocols (e.g. SMTP/POP3 for email which are much easier to use than Lantronix). Unfortunately, Mouser will not ship it outside the USA due to Homeland Security issues.
    Also, Tibbo (http://tibbo.com/products/) has several ethernet-serial adapters some of which can be programmed in their Basic dialect. They have source examples for email, SNTP, etc. on their website. Unfortunately, their XPort like versions are not sold in the USA (I suspect because of Lantronix patents).
