Km to MPH conversion - what am I doing wrong?
Results 1 to 14 of 14
    Default Re: Km to MPH conversion - what am I doing wrong?
    what is the range of the km and mp you need?
    If up to 105 Km is OK with you then a word size variable can do it I think.
    105(km)*621=65205. Scaling by 100 gives 65.205 Miles.
    Or 65205/621 gives back Km. Also if the Miles are scaled up by a factor of 100.
    New Jersey
    Mackrackit's solution may work. I hope to try it today.
    Didn't you need the reverse?
    New Jersey
    No.
    miles = km */ 159
    Should work.
    Like a champ! It's .13 MPH off at 100 MPH and .09 MPH off at 1 MPH. I'm guessing because of the additional numbers needed for a true KM to MPH conversion? Who cares, I don't need it to be that accurate anyway. Thanks again for the help!
    You said you don't need it but you could try miles=km**40718, it should get you a little bit closer still.
