Km to MPH conversion - what am I doing wrong?
Results 1 to 14 of 14
    New Jersey
    Default Re: Km to MPH conversion - what am I doing wrong?
    You don't have to be a smart ass.
    I made my comment because of yours:
    doing a google search I have found that 1 kmh is equal to .6213 mph.
    It's as if you said, "I spent 30 seconds on Google and found out that 1 kmh is equal to .6213. You couldn't have tried to research this problem at all."
    In response to your current question, of
    Why don't you just multiply you km value by 6213/1000? it seems easy to me. maybe I am missing something.
    Yes, you are missing something. Did you read my first post?
    I can do it the other way where it's 6.21.....Then if the speed is over 65 MPH, it rolls over due to a word sized variable.
    Did you ever try to do 98 X 256 X 6.213 on an 18F4550?
    what is the range of the km and mp you need?
    If up to 105 Km is OK with you then a word size variable can do it I think.
    105(km)*621=65205. Scaling by 100 gives 65.205 Miles.
    Or 65205/621 gives back Km. Also if the Miles are scaled up by a factor of 100.
    New Jersey
    Mackrackit's solution may work. I hope to try it today.
    Didn't you need the reverse?
    New Jersey
    No.
    miles = km */ 159
    Should work.
    Like a champ! It's .13 MPH off at 100 MPH and .09 MPH off at 1 MPH. I'm guessing because of the additional numbers needed for a true KM to MPH conversion? Who cares, I don't need it to be that accurate anyway. Thanks again for the help!
    You said you don't need it but you could try miles=km**40718, it should get you a little bit closer still.
