Compiling error on Elapsed timer
Results 1 to 3 of 3
    Jun 2011
    Philippines
    Default Compiling error on Elapsed timer
    Hi everyone, I'm trying out Darrel's sample code from http://darreltaylor.com/DT_INTS-18/elapsed.html.
    asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    DEFINE    OSC 48
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines
            INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    GOSUB ResetTime           ' Reset Time to  0d-00:00:00.00
    GOSUB StartTimer          ' Start the Elapsed Timer
      IF SecondsChanged = 1 THEN
         SecondsChanged = 0
         LCDOUT $FE,2, DEC Days,"d-",DEC2 Hours,":",DEC2 Minutes,":",DEC2 Seconds
    GOTO Main
    But I'm getting some error.
    I'm using pic18f4550, what do I'm missing in the process?
    Thanks in advance,
    tacbanon
    Default Re: Compiling error on Elapsed timer
    You need to use the 18F version of the Elapsed Timer.
    http://darreltaylor.com/DT_INTS-18/downloads.html
    Jun 2011
    Philippines
    Thank you for the reply and for the great work DT...
    /tacbanon
