Newhaven 4x40 LCD, issues!
Results 1 to 28 of 28
    New Jersey
    Default Re: Newhaven 4x40 LCD, issues!
    Sorry, it wasn't Darrell. It was NavMicroSystems in this picture. Anyhow, I literally get nothing. I can't even see the screen flicker. I've verified it has 4.8V at the power input and I've tried using a pot to adjust the contrast. I've only used serial LCD's from SEETRON in the past so this is new to me. Is there a basic way to test the screen? Like applying power to the LCD and +5 to another pin will display something?
    I do not know of a test.
    Post your code and connections/schematic.
    Maybe we will be able to see the problem.
    New Jersey
    Here is what I have:
    DEFINE OSC 20
    @ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_OFF_2L & _BORV_3_2L & _VREGEN_ON_2L
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_32768_2H
    @ __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_ON_4L & _XINST_OFF_4L
    loopcount var word
    ;----[ Change these to match your LCD ]---------------------------------------
    LCD_DB4    VAR PORTE.1
    LCD_DB5    VAR PORTA.3
    LCD_DB6    VAR PORTA.4
    LCD_DB7    VAR PORTE.2
    LCD_RS     VAR PORTD.3
    LCD_E      VAR PORTA.5
    LCD_Lines  CON 2 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 50 ' Data delay time in us
    LCD_COMMANDUS CON 2000 ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments ****
    ;----[ Your Main program starts here ]----------------------------------------
    'LoopCount VAR WORD PAUSE 500 : LCDOUT $FE,1 : PAUSE 250 ; Initialize LCD (You may not need this, ; but some displays are picky)
    Main: LCDOUT $FE,1 ; clear screen
    LCDOUT $FE,$87,"Hello,",$FE,$C8,"From DT!"
    FOR LoopCount = 0 TO 65535
        LCDOUT $FE,$80, IDEC LoopCount
        LCDOUT $FE,$C0, IHEX4 LoopCount
    NEXT LoopCount
    GOTO Main
    Pin connections are as follows:
    1 VSS
    2 VDD
    3 10K POT
    4 PORTD.3
    5 VSS
    6 PORTA.5
    7 N/C
    8 N/C
    9 N/C
    10 N/C
    11 PORTE.1
    12 PORTA.3
    13 PORTA.4
    14 PORTE.2
    15 N/C
    16 N/C
    Did you turn the ADC off someplace ?
    New Jersey
    That's the entire code. I rechecked everything and everything looks okay. I bought two LCD's so when I get home I'll try the other one. I don't know what else I can check. I have an old Mikroelectronica board that has pins for parallel LCD's so maybe I'll use that with the standard code (all pins on the same port) to see if it's my hardware or software that's causing the issue.
    With those configs ... the PIC is running at 48mhz, not 20.
    So change the DEFINE OSC 20 to DEFINE OSC 48.
    And like Dave mentioned ... add ADCON1 = $0F before the LCD pins/include.
    Alabama,USA
    Christopher, I had all my wiring correct and the code looked good but I still had no display. The problem was Vo. The contrast was a critical adjustment. Once I found the sweet spot, just above 0 VDC, all was well.
    I've attatched a txt file with the code to test the LCD using E1 & E2, no other hardware needed. R/W can be tied to GND or to an output. Make the necessary VAR pin assinment changes. This code will write to all four lines without using LCDOUT command.
    Wayne
    Newhaven_4x40_Test Code (1).txt
    Last edited by mackrackit; - 7th September 2012 at 21:31. Reason: Updated attachment by request.
    New Jersey
    I've tried everything you guys suggested and still no dice.
    I went back to the normal LCDOUT commands where I have everything on PORTB. I've tried my Easypic3 board and the 2X16 LCD that came with it, along with 3 other LCD displays I had laying around. I get one line of solid characters, which of course is adjustable with the contrast POT on the board. The LED blinks as intended but nothing on the LCD screen. Do I need to pull up or down any other lines? Is there anything else I can check?
    I'm thinking it might be my files or programmer, but my other programs program just fine. I even reinstalled the PBP file that I modified last night for DT's program but I get the same results. Anything else I can check?
