R/W goes to VSS.
8 bit is a tad faster by the math but I do not think it is humanly noticeable. I never use 8 bit as pins get ...expensive...
R/W goes to VSS.
Are you sure the R/W pin goes to ground? DT's program and the datasheet both show that R/W gets connected to the PIC. I ask because I'm not getting anything on the screen. DT's programs seems to have complied just fine, although I'm not sure if I did everything correctly.
Not sure where you saw Darrel connecting RW to the PIC, in fact he says not to in this post.
http://www.picbasic.co.uk/forum/show...=2388#post2388
The R/W pin is exactly what it says Read/Write, with 0 being Write.
Do you have the contrast pin connected to a pot as recommended? That is the most common problem. That should be pin #3 on the display. Not sure why the data sheet does not so it. Got to have contrast control.
Sorry, it wasn't Darrell. It was NavMicroSystems in this picture. Anyhow, I literally get nothing. I can't even see the screen flicker. I've verified it has 4.8V at the power input and I've tried using a pot to adjust the contrast. I've only used serial LCD's from SEETRON in the past so this is new to me. Is there a basic way to test the screen? Like applying power to the LCD and +5 to another pin will display something?
I do not know of a test.
Post your code and connections/schematic.
Maybe we will be able to see the problem.
Here is what I have:
Pin connections are as follows:Code:DEFINE OSC 20 @ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H @ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_OFF_2L & _BORV_3_2L & _VREGEN_ON_2L @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_32768_2H @ __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_ON_4L & _XINST_OFF_4L loopcount var word ;----[ Change these to match your LCD ]--------------------------------------- LCD_DB4 VAR PORTE.1 LCD_DB5 VAR PORTA.3 LCD_DB6 VAR PORTA.4 LCD_DB7 VAR PORTE.2 LCD_RS VAR PORTD.3 LCD_E VAR PORTA.5 LCD_Lines CON 2 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines) LCD_DATAUS CON 50 ' Data delay time in us LCD_COMMANDUS CON 2000 ' Command delay time in us INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments **** ; ;----[ Your Main program starts here ]---------------------------------------- 'LoopCount VAR WORD PAUSE 500 : LCDOUT $FE,1 : PAUSE 250 ; Initialize LCD (You may not need this, ; but some displays are picky) ; Main: LCDOUT $FE,1 ; clear screen LCDOUT $FE,$87,"Hello,",$FE,$C8,"From DT!" ; FOR LoopCount = 0 TO 65535 LCDOUT $FE,$80, IDEC LoopCount LCDOUT $FE,$C0, IHEX4 LoopCount NEXT LoopCount GOTO Main
1 VSS
2 VDD
3 10K POT
4 PORTD.3
5 VSS
6 PORTA.5
7 N/C
8 N/C
9 N/C
10 N/C
11 PORTE.1
12 PORTA.3
13 PORTA.4
14 PORTE.2
15 N/C
16 N/C
Did you turn the ADC off someplace ?
