Newhaven 4x40 LCD, issues!
Results 1 to 28 of 28
    Alabama,USA
    Default Newhaven 4x40 LCD, issues!
    For the past few days I’ve been working with a Newhaven 4x40 Character LCD. The Newhaven NHD-0440WH-ATMI-JT has duel ST7066U controllers. I have written an Initializing routine outlined in the datasheet but “NOTHING”. No cursor, no characters, “NADA”. I have tried PBP LCDOUT using E1 only, no luck here either. Even if that worked I am not sure how to handle E1 & E2 in the LCDOUT command. Can a port assinment DEFINE such as LCD_EBIT be changed with use of the bas. file, PORTL?
    Blinky light routine works fine. Any Ideas anyone?
    The datasheet reads as if the LCD is in fact two (2x40) LCD’s
    16F886 at 4Mhz
    I tried to slow the 16F886 to 2Mhz, OSCCON=$50 but PBP didn’t like it.
    LCD pinout -------- 16F886 Pin#
    1. DB7……..PortA.7……….9
    2. DB6……..PortA.6……….10
    3. DB5……..PortA.5……….7
    4. DB4……..PortA.4……….6
    5. DB3……..PortA.3……….5
    6. DB2……..PortA.2……….4
    7. DB1……..PortA.1……….3
    8. DB0……..PortA.0……….2
    9. E1………..PortC.0……….11
    10. R/W…..PortC.3……….14
    11. RS……..PortC.2……….13
    12. Vo…….….Center pin 20k pot – 0.5V
    13. Vss…….…GND
    14. Vdd……...5v
    15. E2………...PortC.1……...12
    16. NC…….….GND
    17. LCD+……100 ohm to 5V
    18. LCD-…….GND
    ;16F886
    @ DEVICE MCLR_OFF,BOD_OFF,WDT_ON,LVP_OFF
    define osc 4
    OSCCON=$60              ;70=8MHz, 60=4MHz, 50=2MHz, 40=1MHz.
    ANSEL=$00
    ADCON0=$00
    CM1CON0= 0
    CM2CON0= 0
    ANSELH=$00
    PortA=0
    PortB=0
    PortC=0
    TrisA=0
    TrisB=0
    TrisC=0
    'Constents
    Wakeup        CON $30
    FunctionSet   CON $38    ;Function Set = 8bit mode; 2-line; 5x8
    DisplayON     CON $0C    ;Turn on display; no cursor
    DisplayOnBcursCON $0F ;display on with blinking cursor
    DisplayOFF    CON $08    ;Turn off display
    EntryMode     CON $06    ;Entry mode cursor increment
    ClearDisp     CON $01     ;Clear display
    Home          CON $02     ;cursor set to home position
    'Variables
    Avar var byte
    Bvar var byte
    Cvar var byte
    Dvar var byte
    LED  Var PORTB.1
    E1   var PORTC.0  ;top 2 lines of display
    E2   var PORTC.1  ;bottom 2 lines of display
    RS   var PORTC.2
    RW   var PortC.3
    'EEPROM
    Data @0, " Hello World line1  " '20bites
    Data @20," Hello World line2  " '20bites address C0h  E1
    Data @40," Hello World line3  " '20bites
    Data @60," Hello World line4  " '20bites address C0h  E2
    Start:
         goto Main
    Blinky:
            led =0
            for Avar=1 to 4
            toggle led
            toggle led
            next avar
    ;INIT_LCD_SUBS
    Command1:                              'command sub for upper 2 lines
            PortA=Cvar
            Rs=0
            RW=0
            E1=1
            pause 5
            E1=0
    Command2:                              'command sub for lower2 lines
            PortA=Cvar
            Rs=0
            RW=0
            E2=1
            pause 5
            E2=0
    Writedata1:                                'Write to upper 2 lines
            PortA=Cvar
            Rs=1
            RW=0
            E1=1
            pause 5
            E1=0
    Writedata2:                                'Write to lower 2 lines
            PortA=Cvar
            Rs=1
            RW=0
            E2=1
            pause 5
            E2=0
    TestBusyFlag1:                             'waits until BF is clear to return
            PortA=$FF
            Rs=0
            RW=1
            E1=1
    RBF:
            @nop
            @ BTFSC    PortA.7
            goto RBF
            Rs=1
            RW=0
            E1=0
    INIT_LCD:
    'Wakeup
            Cvar = Wakeup
            gosub Command1
            gosub Command2
            pause 2
    'Wakeup
            Cvar = Wakeup
            gosub Command1
            gosub Command2
            pause 2
    'Wakeup
            Cvar = Wakeup
            gosub Command1
            gosub Command2
            pause 2
    ;FunctionSet                                   ;Function Set = 8bit mode; 2-line; 5x8
            Cvar = FunctionSet
            gosub Command1
            gosub Command2
            pause 2
    'Display Off
            cvar = DisplayOFF
            gosub Command1
            gosub Command2
            pause 2
    'Display Clear
            Cvar = ClearDisp
            gosub Command1
            gosub Command2
            pause 2
    'Entry Mode Set                                  ;Entry mode cursor increment
            cvar = EntryMode
            gosub Command1
            gosub Command2
            pause 2
    'Display On
            cvar = DisplayOnBcurs                ;Turn on display; with blinking cusor
            gosub Command1
            gosub Command2
            pause 2
    Main:                             'Write "Hello World"
            GOSUB Blinky
            GOSUB INIT_LCD
    Message_line1:
            Cvar=Home            ;Set DDRam address for line 1
            gosub Command1
            avar = 0                ;starting address of EEprom first message
            Bvar = Avar + 20
            WHILE Avar < Bvar
            read Avar, Cvar
            Avar = Avar + 1
            gosub Writedata1    ;write Cvar(contents of EEProm character) to LCD
            WEND
    Marktime:
            toggle led
            toggle led
            goto Marktime
    Alabama,USA
    Default Re: Newhaven 4x40 LCD, issues!
    I have a display now. After making some fine adjustments to Vo, characters are writing as they should. Using both LCDOUT and hammering out the commands as in the code above. More to come!
    A 4x40 is really two 2x40's.
    And it can be handled this way ... http://www.picbasic.co.uk/forum/show...=2388#post2388
    Alabama,USA
    Thanks for the link Darrel, I'll check this out. It looks like it will solve my problem.
    Thanks again!
    Wayne
    New Jersey
    Talk about timing. I just received two Newhaven OLED 4x20 LCD's in the mail today (http://www.newhavendisplay.com/specs...420DZW-AY5.pdf). A couple of questions:
    I am putting this on a Microchip demo board (MCP2515) and I can't use all of Port B. Can I use any 8 pins that are free? Also, what is 4 bit operation and is it worthwhile to use it? The datasheet says that 4 lines aren't used when it's in 4 bit operation so I'm curious of using 4 less pins would be advantageous without losing any clarity on the LCD screen.
    Sorry to hi-jack the thread but it seems appropriate in this case.
