16f628a usart
Results 1 to 8 of 8
Thread: 16f628a usart
    Nov 2008
    Default 16f628a usart
    Hello everyone,
    does anyone have a working example using a 16f628a USART? I am trying to just send a byte and echo it back to the serial terminal. I am using a Easypic7. Thanks for any help.
    CharlieM
    Using PBP3
    MCSPX
    Default Re: 16f628a usart
    Nov 2008
    Thanks for the reply Mackrat. I will try it,but I don't see how that will work for a 16F628a.
    CharlieM
    Using PBP3
    MCSPX
    Quote Originally Posted by c_moore View Post
    Why would it not work? It is a demo on how to use the hardware serial port.
    Nov 2008
    Hi Mackrackit,
    Im using a 16f628a and it looks like the code is for a 16F877a or something because it uses port C 6 and 7 for rx and tx. anyway I got something working. it turns out that on a easypic7 when using a 16f pic I needed to use the 18B socket. so once I got the right socket everything started working. thanks.
    CharlieM
    Using PBP3
    MCSPX
    Feb 2003
    Look at the Datasheets. 16F877 uses C6 and C7 as you say, but the 16F628 used B1 RX and B2 TX
    the only thing that I can see needs changing from a quick glance is the line....
    TRISC = %10111111
    to
    TRISB = %11111011
    Keith
    www.diyha.co.uk
    www.kat5.tv
    aliciaDJones's Avatar
    aliciaDJones Guest
    What is 16f628a usart ???
    Quote Originally Posted by aliciaDJones View Post
    UNIVERSAL SYNCHRONOUS ASYNCHRONOUS RECEIVER TRANSMITTER (USART)
    RX=receive
    TX=transmit
    Look at Hserin/Hserout commands in PBP manual.
    Info on 16F628A can be found here:
    http://ww1.microchip.com/downloads/e...doc/40044f.pdf
