Problems with PICKit 2 and Microcode Studio
Results 1 to 11 of 11
    Default Re: Problems with PICKit 2 and Microcode Studio
    Sometimes it only starts when I unplug the programming plug from the programmer.
    I will assume you are not powering the chip with the PicKit?
    Is the chip still in the EPIC when you use the PicKit?
    Maybe a picture of your setup?
    Apr 2007
    Santiago, Chile
    Hi Dave,
    I have attached a photo of my setup. The programming cable that I use is the same as I used for the EPIC except the MCLR pin had to be swapped position.
    The PIC is powered by the board and the PICKit2 is set to Automatic power detect. It seems to be programming fine when the code is right.
    I really as stumped with this....
    Chris
    Apr 2007
    Santiago, Chile
    Hi All,
    I solved the mystery of the PICkit2 and EPIC.
    The difference was the assembler. I programmed using both programmers on my old PC which had MPLAB installed properly and directed MCstudio to the program files/microchip directory.
    On my new PC/notebook I just put MPASM in a directory and directed MCstudio there. I now installed MPLAB 8.7 on the notebook and pointed MCstudo to that and hey presto the programmer worked.
    The final tricky part was to get the programmer to work using the command driver. I just put pk2cmd.exe in a directory and pointed MCstudio to that and then added the following line to the parameters box: -pPIC$target-device$ -f$hex-filename$ -M -R -T -h2.
    Now it's "compile & program" like i had it before with the EPIC!!!
    Hooray!
    Thanks for you input Dave, you helped me find what were not problems!
    Glad to have been a help!
