How to control step motor in accurate timeing
Results 1 to 1 of 1
Threaded View
    Aug 2012
    Default How to control step motor in accurate timeing
    Hi All:
    I am new in Picbasic Pro. I have big problem ,how to write a program to control a stepping motor in accurate timeing.
    I use 16F628A and external crystal, two push switch botton(A and B), ULN2003 drive a 5V stepping motor.
    The concept is when swith on... motor run clockwise something like 10steps every 2Hz all the time and if
    push switch A motor run clockwise as fast as the moter can,or push swith B motor run anticlockwise fast
    also. If release swith, motor run 10steps ever 2Hz all the time.
    I aleady study in PIC like run stepping motor clockwise, anticlockwise, count step to run, digital clock.
    I found Paul Borgmeier made ''Easy & Accurate clock wih out RTC IC''
    His code like this(I do test His code realy accurate )
    Use PIC 12F629
    CMCON=7 'all digital for low power use
    GPIO=0
    TRISIO=0
    OPTION_REG=%10000111 'weak pullups off, TMRO prescale = 256
    INTCON=0 'interrupts off
    HzTimer VAR Word '1/2 second counter (2 Hz)
    HH VAR Byte ' Hours 0-23
    MM VAR ByTE ' Minutes 0-59
    SS VAR Byte ' Seconds 0-59
    col VAR Bit ' colon 1=on, 0=0ff
    HzTimer=$7A12 'for 1/2 Sec
    HH=12:MM=0:SS=0:col=0 'initial conditions (12:00 O'clock noon)
    ClockLoop: IF intcon.2=0 THEN ClockLoop 'Poll for TMRO overflow
    INTCON.2=0 ' Clear TMRO overflow flag
    HzTimer=HzTimer-$1000 'decrement timer count
    IF HzTimer < $1000 THEN
    IF Col=1 THEN ' update time'
    SS=SS+1
    GPIO.1=0 ' Turn off GP1
    IF SS=60 THEN ' minute
    SS=0
    MM=MM+1
    IF MM=60 THEN ' hour
    MM=0
    HH=HH+1
    IF HH=24 THEN HH=0
    IF HH=20 then GPIO.0 = 1 ' Turn on GP0 at 8:00pm
    GPIO.1=1 ' Turn On GP1 for 1 second on the hour
    ENDIF ' Adjust these to meet your needs
    if MM=15 then GPIO.0 = 0 ' Turn off GP0 at 8:15pm
    Col=Col+1
    HzTimer=HzTimer+$7A12 ' Add 0.5 seconds to count
    ' Do something here but must be less than 65.5 mSec
    GOTO Main 'forever
    My code run stepping motor like this
    Use PIC16F628A 4Mhz x'tal, with IC4060 x'tal32.768kHz generate 2Hz to PORTB.3
    TRISA = %00000000
    DIS VAR BYTE
    J VAR BYTE
    K VAR BYTE
    V VAR BYTE
    A VAR BYTE
    D VAR BYTE
    O VAR BYTE
    Start : INPUT PORTB.0
    INPUT PORTB.1
    IF PORTB.0 = 1 THEN Setclock
    IF PORTB.1 = 1 THEN Setacw
    IF PORTB.0 = 0 THEN Startclock
    IF PORTB.1 = 0 THEN Startclock
    GOTO Start
    Setclock : TRISA = 0
    Mstep VAR BYTE
    Steps VAR BYTE
    PORTA = 0
    Mstep = 0
    FOR Steps = 1 TO 4
    PORTA = DCD Mstep
    PAUSE 3
    PORTA = 0
    Mstep = Mstep+1
    IF Mstep>3 THEN Mstep = 0
    NEXT Steps
    GOTO Start
    Setacw : TRISA = 0
    PORTA = 0
    Mstep = 0
    FOR Steps = 1 TO 4
    PORTA = DCD (3-Mstep)
    PAUSE 3
    PORTA = 0
    Mstep = Mstep+1
    NEXT Steps
    GOTO Start
    Startclock : FOR V = 0 TO 87
    FOR K = 0 TO 1
    GOSUB Negative
    NEXT K
    FOR J = 0 to 3
    Motorrun : DIS = 00000001
    M : PORTA = DIS
    PAUSE 3
    DIS = DIS<<1
    NEXT J
    IF DIS <> %00100000 THEN M
    NEXT V
    Startclock2: FOR O = 0 TO 1
    FOR A = 0 TO 211
    GOSUB Negative
    FOR D = 0 to 3
    Motorrun2 : DIS = 00000001
    M2 : PORTA = DIS
    PAUSE 3
    DIS = DIS<<1
    NEXT D
    IF DIS <> %00100000 THEN M2
    NEXT A
    NEXT O
    GOTO Startclock
    Negative : IF PORTB.3 = 0 THEN Negative
    Positive : IF PORTB.3 = 1 THEN Positive
    I am very poor in INTERRUPT(and speak english!) so any one please tell me how to combine two code in one
    program. And I don;t need IC CD4060/Xtal 32.768kHz any more.
    Pichai Han from Bangkok Thailand.
