GPS decoding
Results 1 to 3 of 3
Thread: GPS decoding
    Feb 2004
    Germany
    I dont know that particular Receiver Model, but most GPS Receivers support NMEA Data.
    if you hook up the receiver to your PCs COM Port and capture the incomming data in Hyperterm (4800 8N1) you should see something like:
    $GPVTG,054.7,T,034.4,M,000.5,N,000.9,K*47
    $GPRMC,225446,A,4916.45,N,12311.12,W,000.5,054.7,1 91194,020.3,E*68
    $GPRMB,A,0.66,L,003,004,4917.24,N,12309.57,W,001.3 ,052.5,000.5,V*0B
    $GPBWC,225444,4917.24,N,12309.57,W,051.9,T,031.6,M ,001.3,N,004*29
    $GPWPL,4917.16,N,12310.64,W,003*65
    $GPGLL,4916.45,N,12311.12,W*71
    If 4800 8N1 doesn't work try 9600 8N1 and other Baudrates.
    If your receiver sends Data of that type: Google for NMEA 0183" and you'll find all you need.
    regards
    Ralph
    Macgman2000's Avatar
    Macgman2000 Guest
    Default GPS Decoding
    Hello Ralph,
    Yes it worked at 4800 8N1 like you suggested. I will look up the spec and see what I can do with it. Thanks for your help!!!!
    Best Regards,
    Nick
  1. GPS decoding problems
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 25th February 2012, 11:57
  2. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 10:47
  3. GPS clock timing !
    By bethr in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 21:11
  4. Replies: 2
    Last Post: - 28th April 2006, 13:10
  5. GPS Receiver
    By lester in forum Adverts
    Last Post: - 22nd February 2006, 13:47
