Math problem
Results 1 to 6 of 6
Thread: Math problem
    New Jersey
    Default Math problem
    I need to understand this code and convert it to PBP code. I *think* it's for another microcontroller.
    v[0]=0.1*(((d[0]&#0111)-(d[0]&#1000))*256+d[1])
    I don't understand what the & and # signs are really doing. I also don't understand why they have 7 in the left and 8 in the right. Why not just just use 1? I'm sure there's a reason for it but I don't understand why.
    Feb 2003
    Default Re: Math problem
    Just a guess that the & is a Logical AND and that the # is used as an indicator for binary so the the variable d[0] is being masked to get bits 0-2 in the first case and bit three in the second case. eg (d[0] AND 7) -(d[0] AND 8)
    Of course I could be way off base LOL
    Keith
    www.diyha.co.uk
    www.kat5.tv
    New Jersey
    Quote Originally Posted by keithdoxey View Post
    Using the binary numbers as a mask is a good guess. I'm not a math expert. When the term logical is used, what exactly does it mean?
    Feb 2003
    It means the mask is applied to the variable being masked and bacause it is an AND, only the bits that are a 1 in both number appear in the result eg assume the number 26 for d[0]
    00011010 = 26 = d[o]
    00000111 = 7 = 1st mask
    00000010 = 2 = 1st result
    00001000 = 8 = 2nd mask
    00001000 = 2 = 2nd result
    Hope that makes sense
    Keith
    www.diyha.co.uk
    www.kat5.tv
    New Jersey
    I see why they use that formula. What's an easy way (fast/less code) to convert this number into usable information.
    The first byte will go from 0 to 7 but also from 15 to 8. When it is 0-7, the number is negative....0, -1, -2, -3..... When it is 15 to 8 (stepping down), the number is positive. In this case 15=1, 14=2, 13=3.....
    I'm still not sure I understand the original equation correctly but when I was driving I got something like this:
    D0=15 and D1=243. I know this is charging current and D0=1, which is a rollover from D1. In other words, once D1 increases from 255 to 256, D1 goes to 0 and D0 increases by 1. In this case, it went from 15 to 0. More current stepped down from 15 to 14. How would I apply this to that formula:
    v[0]=.1*(((7)-(8))*256+243
    v[0]=.1*(-1)*256+243
    v[0]=-.1*256+243
    v[0]= -25.6 + 243
    v[0] = 217.4
    This number doesn't seem correct from a functional perspective but also when plugging in 14 in D0, I would expect the number to increase, not decrease. Is my math above correct?
    Bombay, India
    Hi Christopher
    Your equation simply does this calculation
    v[0] = 0.1 * number
    where
    Number is the value in d[0], d[1] MSB, LSB
    Number ranges from -7 to +7 where bit 3 (weight 8) is the sign bit.
    How does it work? Let's break it up
    Keep aside the 0.1 for the moment
    Starting with ( ( (d[0] & #111) ....
    you keep only bits 0,1,2 of the MSB (max value of #111 is 7)
    ......-(d[0]&#1000))
    subtract 0 for d[0].3 = 0 or 8 if d[0].3 is 1
    d[0].3 is 1 when the number is negative.
    ( ( (value)-(weight of sign bit) ) * 256 ) ...
    Now, multiply this number by 256 or in binary 100hex. Simply means the author wants to move the MSB number by 8 bits left.
    Equivalent code would be "MSB number left shifted by 8 bits"
    (...... + d[1] )
    Now, add in the LSB of the number to get the whole 12bit (4 from msb, 8 from lsb) value
    Now you have the entire number with its sign taken care of in some temporary variable generated by the compiler.
    v[0] = 0.1 * temporary number
    This is the part PBP will not be able to handle for you since it does not accept fractions.
    What you can do to overcome this is
    v[0] = temp number / 10 which is the same as 0.1 * temp number
    Cheers
    Jerson
