Software reset - What am I doing wrong?
Results 1 to 15 of 15
Threaded View
  1. #10
    New Jersey
    Default Re: Software reset - What am I doing wrong?
    This is what Microchip uses for the config files. When their program is loaded, the power up sequence works fine so I don't think my issue is in the config file. If I can get the software reset to work correctly I would be golden.
    #pragma config PLLDIV   = 5         // (20 MHz crystal on PICDEM FS USB board)
            #pragma config CPUDIV   = OSC1_PLL2
            #pragma config USBDIV   = 2         // Clock source from 96MHz PLL/2
            #pragma config FOSC     = HSPLL_HS
            #pragma config FCMEN    = OFF
            #pragma config IESO     = OFF
            #pragma config PWRT     = OFF
            #pragma config BOR      = OFF
            #pragma config BORV     = 3
            #pragma config VREGEN   = ON      //USB Voltage Regulator
            #pragma config WDT      = OFF
            #pragma config WDTPS    = 32768
            #pragma config MCLRE    = ON
            #pragma config LPT1OSC  = OFF
            #pragma config PBADEN   = OFF
          #pragma config CCP2MX   = ON
            #pragma config STVREN   = ON
            #pragma config LVP      = OFF
            #pragma config ICPRT    = ON       // Dedicated In-Circuit Debug/Programming
            #pragma config XINST    = OFF       // Extended Instruction Set
            #pragma config CP0      = OFF
            #pragma config CP1      = OFF
          #pragma config CP2      = OFF
          #pragma config CP3      = OFF
            #pragma config CPB      = OFF
          #pragma config CPD      = OFF
            #pragma config WRT0     = OFF
            #pragma config WRT1     = OFF
          #pragma config WRT2     = OFF
          #pragma config WRT3     = OFF
            #pragma config WRTB     = OFF       // Boot Block Write Protection
            #pragma config WRTC     = OFF
          #pragma config WRTD     = OFF
            #pragma config EBTR0    = OFF
            #pragma config EBTR1    = OFF
          #pragma config EBTR2    = OFF
          #pragma config EBTR3    = OFF
            #pragma config EBTRB    = OFF
    EDIT: My configs do match Microchips, I just changed them today to try and rectify this issue.
