High power resistor
Results 1 to 4 of 4
    Sep 2006
    Default High power resistor
    Hello,
    Anyone knows where i could order high power resistor, variable would be a plus. I have 840V dc, and i would like to chose anywhere between 700Ohm (1000watt) to 5KOhm (150watt).
    I can locate companies like Ohmite or Token, but they do not sell directly and mouser or digikey do not hold there product at that power rating ..
    thanks for any help
    ken
    Oct 2009
    Utah, USA
    Default Re: High power resistor
    Hi lerameur,
    A resistor that can disipate 1000 watts is called a heater. Seriously... most portable room heaters are 1000-1500 watts.
    I doubt that you are going to find a single resistor that can disipate that kind of heat. I have a coil wound cermic heater that is rated at 1000 watts. It gets red hot after about 30 seconds.
    How long do you want to dissapate that kind of heat energy??
    You may have to go with a switchable array of resistors... say 10 watts X 100 resistors or 200 x 5 watts.
    There are solid state (FET I think) loads that have a fan mounted for cooling... like these http://www.westmountainradio.com/cba.php
    Buy you are talking a very high voltage... which complicates the matter even more.
    good luck
    dwight
    Dwight
    Apr 2011
    Yes, unless you specifically WANT a heater, why would you require such a resistor? Power control is usually done using PWM these days.
    aliciaDJones's Avatar
    aliciaDJones Guest
    What is I don't now bout this pleas tell me about this...
