minimising 18F basic operational current!
Results 1 to 4 of 4
    Sep 2009
    South Wales (UK)
    Default minimising 18F basic operational current!
    Now that I've had help with the WDT, the other issue is the minimisation of the running current when the device is awake. I have an 18F26J53 on a bit of strip board with a couple of LEDs. When sleeping, my 'cheap' multimeter reads 0.03 mA (nice!), but when not sleeping, but simply in a pause for 3 seconds, it's drawing just over 10 mA! The LEDs are not powered on, as far as I can tell, I've powered down all the possible internal modules with PMDIS0-3, switched ports to digital and set all low.
    What is drawing 10 mA?!!!
    If I can resolve this I'm onto a winner!
    Best regards to all fellow PBP'ers!
    Cheers
    Jimbo
    The .inc file...
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F26J53, r = dec, w = -311, f = inhx32
            INCLUDE "P18F26J53.INC"	; MPASM  Header
            CONFIG XINST = OFF
    	CONFIG PLLDIV = 2; 4
    	CONFIG WDTPS = 512;512
    	CONFIG WDTEN = ON
            CONFIG OSC = INTOSCPLL       ;HSPLL;
            CONFIG ADCSEL = BIT12
    	CONFIG RTCOSC = T1OSCREF
    	CONFIG IESO = OFF
    	CONFIG CFGPLLEN = ON
    	CONFIG CPUDIV = OSC1
    	CONFIG CLKOEC = OFF
    	CONFIG SOSCSEL = LOW
    	CONFIG DSBOREN = OFF
            NOLIST
            LIST
    BLOCK_SIZE	EQU	64
    The code...
    Include "modedefs.bas"
    DEFINE OSC 24
    ancon0 = %11111111
    ancon1 = %00011111
    intcon  = 0
    intcon2 = %11110101
    intcon3 = %00000000
    ADCON0                  =   0
    ADCON1                  =   0
    trisa                   =   %00000000
    trisb                   =   %00000000
    trisc                   =   %00000000
    low porta
    low portb
    low portc
    pmdis0 = %11111111
    pmdis1 = %11111111
    pmdis2 = %11111111
    pmdis3 = %11111111
    WDTCON.0 = 1
    pause 3000
    @ sleep
    @ nop
    Sep 2009
    South Wales (UK)
    Default Re: minimising 18F basic operational current!
    ok, just realised I can't say 'low port a' etc so have switched that to porta = %00000000 etc...
    I've also disabled USB I think with UCON = %00010000 and UCFG = %00001000
    but still, this circuit is drawing 10 mA doing nothing but pausing. I'm really stuck
    Hi Jimbo,
    pause does not put the chip in any kind of sleep state. It is busy counting. And from page 520 of the data sheet, it says at 48 mhz, the chip will use 19.5 ma. So, at 24 mhz, it should use half that, which is equal to about what you are seeing. To use minimal power put it in a sleep mode for as long as you can, and just do periodic work with the chip awake.
    http://www.scalerobotics.com
    Sep 2009
    South Wales (UK)
    Hi there,
    Spot on, and many thanks for your help! I used the internal osc, turned off PLL etc and got it to a couple of mA in the end. One final issue now which I'll start a new thread for... SD cards!!!
    Best regards
    Jimbo
