Multiplex Led Array
Results 1 to 7 of 7
    george's Avatar
    george Guest
    Unhappy Multiplex Led Array
    hi,
    I am building a project moving led array im using pic16f84a as my controller it is connected to 74ls164 shift registers. I can display characters but i cant make them shift ( move the character from right to left). anyone can help me sure would appreciate it.
    This is the program in PBP that i've written (displays character that is in the label cnvrt but can't move them)
    trisb=%00000000
    trisa=%00000101
    x var byte
    z var byte
    clock var porta.4
    my_data var porta.1
    reset var porta.3
    portb=%11111111
    porta=%00000000
    begin:
    high reset
    high my_data
    low clock
    for x=0 to 14
    gosub cnvrt
    portb = z
    high clock
    low my_data
    low clock
    pauseus 150
    next
    low reset
    goto begin
    cnvrt:
    lookup x,[$3c,$5e,$6e,$76,$38,$ff,$89,$76,$76,$89,$ff,$81,$7 6,$76,$8f],z
    It would be easier to explain if we could have referred to your hardware arrangement, however...
    The thing to remember here is the display of your character (which you're probably already doing) RELATIVE to your display "window" at any instant in time...
    There are many ways of doing this... here's one explained as a generalisation...
    Say you have an 8 x 5 LED matrix. That's 8 LED's vertical, and 5 LED's horizontal. This is your display "window". You wish to scroll thru the letter 'A' horizontally. Now the letter 'A' is made up of the following (vertical) lines where each byte represents one vertical column of LED's, and where the five bytes together make up the character 'A'...
    $7C - 01111100
    $12 - 00010010
    $11 - 00010001
    $12 - 00010010
    $7C - 01111100
    Might be a little difficult to visualise until you draw it out (use a blank for zero and a blob for '1' and you find the 'A' is lying on it's R/H side)...
    Now... to scroll thru the character, the element has to pass thru the display window like so...
    $00,$00,$00,$00,$00 - Step 1 - nothing is displayed
    $00,$00,$00,$00,$7C - Step 2 - L/H edge appears
    $00,$00,$00,$7C,$12
    $00,$00,$7C,$12,$11
    $00,$7C,$12,$11,$12
    $7C,$12,$11,$12,$7C - Step 6 - entire character displayed
    $12,$11,$12,$7C,$00 - Step 7 - character starts to scroll thru
    $11,$12,$7C,$00,$00
    $12,$7C,$00,$00,$00
    $7C,$00,$00,$00,$00 - Step 10 - almost gone just R/H edge...
    ... then go repeat all over from Step 1...
    Now, to reitterate... our display consists of five bytes of eight bits, where each bit of that byte represents one column of eight vertical LED's, and the five bytes together make up our five columns. You have to pause displaying one whole set of bytes, before progressing onto the next step (next line of bytes). This pause becomes our scroll speed control. As you progress from Step 1 thru to Step 10 your character 'scrolls' across your display 'window'.
    Probaly clear as mud...
    If you're using serial latches, depending on your method of interconnecting them, you might be able to feed a byte into one end and the byte at the far end falls into oblivion which automatically causes a scroll. This seriously reduces processor overhead as you're only outputting one byte per scroll step (rather than as in our above example five)... but this is another story for another time...
    Melanie
    george's Avatar
    george Guest
    Thumbs up
    Thank you very much Melanie.
    My project is working now. I now intend to improve my project by connecting it to a pc via serial port. Can I edit the message using a pc's serial port and software like VB? What pic micro will I use? What pbp command will do such that I can save all the characters in the alphabet and retrieve it (say each character represents five bytes) so that i don't have to change the the values in the lookup table every time I want to display a new message.
    Sorry if i have so many questions, I'm just eager to learn pic and pbp.
    Merry Christmas and A happy New Year!
    Thanks.
    George
    electronicsuk's Avatar
    electronicsuk Guest
    It would be a good idea to use a chip with a hardware serial port, for example the 16F627. If you only want to display standard characters, you could use some form of lookup to match ASCII values received through serial to their corresponding character.
    Matthew
    george's Avatar
    george Guest
    Arrow
    Thanks Matthew.
    I will try to start my project as you have suggested.
    Happy new year.
    Yes you can.
    16F628, 16F876 etc...
    Well, if I was approaching this task, I would save my display message in the PIC's internal EEPROM, but I would use an external EEPROM (eg 24LC16, 24LC32 etc) to hold my character font - because if you were to replicate the ASCII character set between say $20 and $7F that would be 95 characters*5=475 bytes. Also changing character fonts for different applications or languages then becomes as easy as plugging-in a new EEPROM. As for PBP command... Read, Write and Data would be used for internal EEPROM, I2CREAD and I2CWRITE for the external EEPROM.
    Melanie
    mcglacy's Avatar
    mcglacy Guest
    melanie
    i'm interested....
    Can you please post it here the sample source code...
    thanks
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. DS1307 and a LED array, need ideas
    By peu in forum mel PIC BASIC Pro
    Last Post: - 30th December 2009, 19:45
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. LED Array
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 18th July 2003, 14:41
