Is this a case for CASE?
Results 1 to 3 of 3
    Feb 2004
    Michigan, USA
    Default Is this a case for CASE?
    I have 2 input pins that can be either both off, either one on, or both on. Each combination needs a specific number applied to it.
    both off = 0
    portb.6 on = 2
    portb.7 on = 10
    portb.6 and portb.7 on = 19
    So if both pins where high variable SETPOINT = 19.
    I've tried if then statements but I cant get them to work.
    I tried while wend hoping that while the pin or combo is high the correct value is used but I cant get that to work either.
    Any ideas?
    Default Re: Is this a case for CASE?
    Sure, you can use Select Case. Perhaps something like
    Select Case (PortB & %11000000)
    Case 192
    	SetPoint = 19
    Case 128
    	SetPoint = 10
    Case 64
    	SetPoint = 2
    Case 0
    	SetPoint = 0
    End Select
    But I think IF-THEN will compile to less code but execute a bit slower since it will test all four conditions even if it finds a match in the first one.
    PinStates = PortB & %11000000
    If PinStates = 192 THEN SetPoint = 19
    If PinStates = 128 THEN SetPoint = 10
    If PinStates = 64 THEN SetPoint = 2
    If PinStates = 0 THEN SetPoint = 0
    As with most things there are several ways of doing it and these two are likely not the only ones.
    May 2008
    Italy
    Setpoint  VAR byte [4]
    Setpoint[0]=0
    Setpoint[1]=2
    Setpoint[2]=10
    Setpoint[3]=19
    Main_Loop:
    Setpoint[PortB>>6]
    Goto Main_Loop
    This is an additional solution without If/Then or Select Case.
    Cheers
    Al.
