Multiple IF THEN Statements: PIC16F84A
Results 1 to 6 of 6
    May 2006
    Arrow Multiple IF THEN Statements: PIC16F84A
    Forum Members:
    I am using PicBasisPro Ver 2.50a, Melabs Programmer Ver. 4.40 and MicroCode Studio Ver. 2.0.0.5 for the following PIC16F84A application.
    Even though I have used both the Melabs printer port of the Melabs USB programmers I haven't identified the following problem.
    1. Go to the LOOP section.
    2. The first IF THEN performs as intended.
    3. The second IF THEN does not even execute the "GOSUB pwrup" sub-routine.
    4. If I reverse the IF THEN codes, the first IF THEN section always executes.
    I’ve read the PIC16F84A data sheet and haven’t found, or have overlooked, any constants of using the following code on the PIC16F84A component.
    Perhaps I’m “too close to the trees…”
    Any assistance will be appreciated.
    Bob
    '*  Name : Syn-Ren50.BAS            Author  : Bob Wills              *
    '*  MCU  : PIC 16F84A               USE     : OLIN FOX LIFT          *
    '*  Date : 08/04/2012, Ver. 2.0     PicBasic Pro Compiler            *
    '*  Words: 712                      Duty Cycle:   ~ 0.79 step/1%DC   *
    '*  NOTE: This program controls a BDC motor to move a lift up/down   *
    '*  with the following features:                                     *
    '*  1. Increase the motor speed (up/down) from stop to running speed.*
    '*  2. Decrease the motor speed (up/down) just before the stopping   *
    '*     limit switch.                                                 *
    '*  3. Provide various stopping rates for safety purposes.           *
    '*  4. The motor is controlled by a Dimension Engineering            *
    '*     Single Channel 50A continuous/100A peak, Brushed motor        *
    '*     controller, Model: SyRen50.  This contoller containa a MCU.   *
    '*  5. A PIC16F84A interfaces between the lift inputs and the SyRen50 *
    '*     and sends control signals to the SyRen50 using the PBP        *
    '*     "SEROUT" statement -- SEROUT mtrdat, T2400, [n]               *
    '*  6. SEROUT mtrdat, T9600, [127] = motor stop,                     *
    '*     ...[0] = motor full reverse; ...[255] = motor full forward.   *
    @ DEVICE PIC16F84A, XT_OSC  ' 4Mhz
    @ DEVICE PIC16F84A, WDT_OFF ' Watchdog Timer
    @ DEVICE PIC16F84A, PWRT_ON ' Power-On Timer
    @ DEVICE PIC16F84A, PROTECT_OFF ' Program Code Protection
    stdwnv          con    109      'range 127-0: 96~6vdc, 64~12vdc
    stupv           con    145      'range 127-256: 158~6vdc, 190~12vdc
    upstps          con     30      'up
    dwnstps         con     30      'down
    sloup           con     30      'up end speed
    slodwn          con     30      'down end speed
    i               var     byte
    n               var     BYTE
    upv             var     byte
    dwnv            var     byte
                           'pin
    sss         VAR PORTA.0           'Pin 17  'RA0/AN0                input safety switch
    slo         VAR PORTA.1           'Pin 18  'RA1/AN1                input for slow interrupt
    upstp       VAR PORTA.2         'Pin  1    'RA2/AN2/CVREF/VREF-    input for up stop
    dwnstp      VAR PORTA.3        'Pin  2    'RA3/AN3/VREF+/C1OUT    input for down stop
    '           VAR PORTA.4            'Pin  3    'RA4/AN4/T0CKI/C2OUT    recvr input = down start
    '                                         Pin 4            MCLR
    '                                         Pin 15           OSC2/CLKOUT
    '                                         Pin 16           OSC1/CLKIN
    syrenpwr    VAR PORTB.0        'Pin   6   'RB0/INT/CCP1   output to the syren power relay
    mtrlp       VAR PORTB.1           'Pin  7   'RB1/SDI/SDA    output to the motor loop relay
    mtrdat      VAR PORTB.2          'Pin  8   'RB2/SDO/RX/DT  output data control for syrenpwr
    '           VAR PORTB.3             'Pin  9   'RB3/PGM/CCP1
    rkrup       VAR PORTB.4           'Pin 10   'RB4/SCK/SCL    rocker input for up start
    rcvrdn      VAR PORTB.5          'Pin 11   'RB5/SS/TX/CK   receiver input for down start
    rcvrup      VAR PORTB.6          'Pin 12   'RB6/AN5/PGC/T1OSO/T1CKI ICSP CLOCK
                                              'rcvr input for up start
    '              VAR PORTB.7          'Pin 13   'RB7/AN6(6)/PGD/T1OSI   ICSP DATA Manual Switch
    PORTA = 5               'PORTA MEMORY ADDRESS
    TRISA = 133             'TRISA MEMORY ADDRESS
    TRISA = %11111111  		'SET PORTA DATA DIRECTIONS
    PORTA = %00000000       'CLEAR PORTA MEMORY
    PORTB = 6               'PORTB MEMORY ADDRESS
    TRISB = 134             'TRISB MEMORY ADDRESS
    TRISB = %11111000       'SET PORTB DATA DIRECTIONS
    PORTB = %00000000       'CLEAR PORTB MEMORY
    INCLUDE "modedefs.bas"
    loop:
        if (rcvrup = 0) and (upstp = 1) then
        gosub pwrup
        gosub uprcvr
        gosub pwrdwn
        if (rcvrdn = 0) and (dwnstp = 1) then
        gosub pwrup
        gosub dwnrcvr
        gosub pwrdwn
     gosub loop
    dwnrcvr:             'Increases motor speed from stop to "up speed rate'
        serout mtrdat, T2400, [stdwnv]
        dwnv = stdwnv
        pause 50
        for i = 1 to dwnstps step 1
        dwnv = dwnv - 1
        SEROUT mtrdat, T2400, [dwnv]
        pause 50
           if (rcvrdn = 1) oR (dwnstp = 0)  then   'stop & limit sw
           serout mtrdat, T2400, [127]
           gosub pwrdwn
        next i
        gosub loop
    uprcvr:             'Increases motor speed from stop to "up speed rate'
        serout mtrdat, T2400, [stupv]
        upv = stupv
        pause 50
        for i = 1 to upstps step 1
        upv = upv + 1
        SEROUT mtrdat, T2400, [upv]
        pause 50
           if (rcvrup = 1) oR (upstp = 0)  then   'stop & limit sw
           gosub pwrdwn
        next i
        gosub loop
    pwrup:
        high syrenpwr
        pause 250
        high mtrlp
    pwrdwn:
            serout mtrdat, T2400,[127]
            pause 50
            low syrenpwr
            pause 10
            low mtrlp
            gosub loop
    Default Re: Multiple IF THEN Statements: PIC16F84A
    Gosubs NEED returns to take them off the stack. If you do not wish to return to the next line use goto. I only see return on 1 subprogram. I will look some more.
    edit: so replace gosub loop with return (s)
    Jan 2006
    Istanbul
    Use return instead of calling the main loop again after calling a sub routine.
    Also, use goto instead of callig the main loop within itself again.
    Corrected code is as below.
     '* limit switch. *
     upstps con 30 'up
     i var byte
     n var BYTE
     upv var byte
     dwnv var byte
     'pin
    ' Pin 4 MCLR
     ' Pin 16 OSC1/CLKIN
    loopx:
         gosub pwrup
         gosub uprcvr
        gosub pwrdwn
        gosub pwrup
        gosub dwnrcvr
        gosub pwrdwn
     goto loopx
     dwnv = stdwnv
     pause 50
         dwnv = dwnv - 1
         pause 50
             gosub pwrdwn
     next i
     upv = stupv
     pause 50
         upv = upv + 1
         pause 50
             gosub pwrdwn
     next i
     pwrup:
     high syrenpwr
     pause 250
     high mtrlp
     pwrdwn:
     pause 50
     low syrenpwr
     pause 10
     low mtrlp
    May 2008
    Italy
    On top I would suggest also these two modifications to your subroutine:
    1) Not necessary to serout twice the same code (127)
    2) the Goto Skip will take you out of the For/Next loop
     '* limit switch. *
     upstps con 30 'up
     i var byte
     n var BYTE
     upv var byte
     dwnv var byte
     'pin
    ' Pin 4 MCLR
     ' Pin 16 OSC1/CLKIN
    loopx:
         gosub pwrup
         gosub uprcvr
        gosub pwrdwn
        gosub pwrup
        gosub dwnrcvr
        gosub pwrdwn
     goto loopx
     dwnv = stdwnv
     pause 50
         dwnv = dwnv - 1
         pause 50
             gosub pwrdwn
         Goto Skip_01
     next i
    Skip_01:
     upv = stupv
     pause 50
         upv = upv + 1
         pause 50
             gosub pwrdwn
         Goto Skip_02
     next i
     Skip_02:
     pwrup:
     high syrenpwr
     pause 250
     high mtrlp
     pwrdwn:
     pause 50
     low syrenpwr
     pause 10
     low mtrlp
    May 2006
    Archangel:
    sayzar:
    Thank you so much for you timely insite and help, plus your programming advice for my benefit.
    I'll make those connections and continue with the rest of the code prepatation.
    Bob
    May 2006
    aratti:
    Archangel:
    sayzar:
    All of your comments and suggestions have been quite helpful.
    I finished the code using your help -- now it's PCB time.
    Thanks again,
    Bob
