18F2550 and Blink Led
Results 1 to 40 of 50
    Mar 2008
    Default Re: 18F2550 and Blink Led
    What I was attempting to say with that comment was that by using TRISB = %00001111 after the line containing INTCON2.7 = 0 you would set the bottom 4 bits to outputs causing those 4 bits to no longer have WPU , Maybe I have this backward and it should be TRISB = %11110000 Is this also wrong? As it turns out I need all 8 ports to have WPU’s so I will not be using that line. However for future use I would like to know the correct usage?
    Thank you so much!
    Sep 2010
    Las Vegas, NV
    Try longer pauses.
    Is this also wrong?
    yes its wrong , if you read the datasheet its wpu for all pins that are inputs or no pins have wpu on that port
    Each of the PORTB pins has a weak internal pull-up. A
    single control bit can turn on all the pull-ups. This is
    performed by clearing bit, RBPU (INTCON2<7>). The
    weak pull-up is automatically turned off when the port
    pin is configured as an output. The pull-ups are
    disabled on a Power-on Reset.
    Mar 2008
    "The weak pull-up is automatically turned off when the port
    pin is configured as an output."
    So this means all of the wpu are turned off on portb if any pin is a output on portb? I guess I thought because the data sheet said "The weak pull-up is" not "The weak pull-ups are turned off it meant just that one pin.
    Thank you very much for clearing that up.
    no it means
    if (INTCON2<7>) is set then all portb pull ups are off
    if (INTCON2<7>) is clear then all portb pull ups are on and that no pin that is an output can have a pull up
    Aug 2011
    If there's any confusion on how to set the pin direction, I like to think of it this way... the TRIS register is short for TRI-STATE register.
    If a pin is tri-state, it's floating, so it must be an input. Setting the TRIS bit = 1 enables the tri-state, so 1=input, 0=output.
    Have to get back to this thread
    still having same issue of Block overflow
    but forgot how I've fixed it......
    It is interesting - it will compile for some 18F series, but not for others.
    For example, it will compile for 18F1220, but not for 18F1320, but will for 18F1520
    It will compile for 18F2439 but not for 18F2550.
    It will compile for 18F24K50, but won't compile for 18F24K22.
    For testing purposes, I took my daughters laptop, where no PBP was ever installed, downloaded the trial version and it is absolutely the same...
    If you have #CONFIG / #ENDCONFIG block within your code then you'll likely need to adapt that based on which device you're compiling for since CONFIG bits aren't the same on each and every device.
    I will try it if you can post the complete code that you're trying to compile.
