18F2550 and Blink Led
Results 1 to 40 of 50
    Default Re: 18F2550 and Blink Led
    Place this at the top of your cade and see what happens.
    __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
    Absolutely the same. Does it compiles for you?
    This is what I tested.
    Changed the config to internal though..
    Compiles fine.
        __CONFIG _CONFIG1H, _FOSC_INTOSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
     DEFINE OSC 8
     ADCON1 = %00001111
     CMCON = 7
     OSCCON = %01110000
     TRISB = %00000000
     START:
     LATB.2 = 1
     PAUSE 250
     LATB.2 = 0
     PAUSE 250
     GOTO START
    Strange, gives the same error here, might I need to install update or something similar?
    This is the best I can find that sorta refers to your problem
    http://support.melabs.com/threads/54...config-length?
    but I do not think it applies.
    Maybe try re-installing PBP3? Maybe it became corrupt ?
    Removed PBP, removed mplab and all associated apps, downloaded fresh copy of PBP, installed, still same error.
    Tried to follow this method:
    http://melabs.com/support/mplab.htm
    This time I get: Whitelist: Processor 18F2550 disabled in this version of PBP.
    To obtain additional device support, visit melabs.com.*
    Edition is student edition and 18F2550 is definitely included.
    Restarted the PC, and now compile trough MPLAB works fine, but it is not handy to do so.
