Hello,
What a silly mistake... You are wright Darrel, i'm compiling always with the ICD Compile...
Thanks for your help, it's solved.
Nuno
Hello,
Nuno
I'm trying to just compile the code below:
It gives Block overflow for #ENDCONFIG.Code:' PIC18F2550 DEFINE OSC 8 ADCON1 = %00001111 CMCON = 7 OSCCON = %01110000 TRISB = %00000000 START LATB.2 = 1 PAUSE 250 LATB.2 = 0 PAUSE 250 GOTO START
MCU is 18F2550
What might be the reason?
It does not helps. Still:
[ERROR] program files (89) : Block overflow for #ENDCONFIG
Post your whole cide and PBP version.
Whole code is already posted, PBP is PBP3.
Place this at the top of your cade and see what happens.
__CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
__CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
__CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_ON_2L & _BORV_3_2L & _VREGEN_ON_2L
__CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
__CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
__CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L
