PIC programs, resonator resonates, but does not run code.
Results 1 to 10 of 10
    Feb 2004
    Michigan, USA
    Default PIC programs, resonator resonates, but does not run code.
    Baffling problem. The code was tested fine on an 18 pin 18F1320 on a breadboard, the pcb uses a 20 pin 18F1320. The 20mhz resonator runs perfectly. A test program using internal RC doesnt run either. I can program and read back the code and it verified ok. Also, this is 2 different PIC's in a row.
    Any ideas what the heck the issue is? Anyone seen this before?
    Here is a short test program to turn on and off a pin:
    Define OSC 20
    ADCON1 = %01111000
    ADCON2 = %10000111
    TRISA = %11100111
    TRISB = %11000011
    loop1:
    portb.2 = 1
    portb.2 = 0
    goto loop1
    I'm programming using HS just as I did on the breadboard. MCLR is set as an input.
    Nov 2007
    West Covina, CA
    Default Re: PIC programs, resonator resonates, but does not run code.
    Add another PAUSE 100 to your test loop so you can see it go low.
    loop1:
    portb.2 = 1
    portb.2 = 0
    PAUSE 100
    goto loop1
    Louie
    Feb 2004
    Michigan, USA
    Thanks.
    It never actually goes high though.
    Feb 2004
    Michigan, USA
    Well, a third PIC shows the exact same behavior. It will program and verify fine but will not execute code. I changed the resonator, same result. Will try a new pcb next.
    Feb 2004
    Michigan, USA
    New pcb, new PIC, same result. Only populated the board with a 5v regulator and caps, plus resonator and PIC. Layout is good. Can program, verify, read back, erase etc etc. Again, resonator is showing clean 20mhz waveform, it just will not execute the code.
    Aug 2008
    Portugal
    Try this please;
    loop1:
    LATB.2 = 1
    LATB.2 = 0
    PAUSE 100
    goto loop1
    Also check if MCLR is connected to VCC. I don't see the configuration bits of your code!
    Thanks and Regards;
    Gadelhas
    Nov 2007
    West Covina, CA
    Confusing since it worked on the 18 pin but I would also try configuring in the order shown in Example 10-2 of the data sheet:
    PORTA = %00000000       ' Turn off all PORTA
    PORTB = %00000000       ' Turn off all PORTB
    ADCON1 = %01111000
    ADCON2 = %10000111
    TRISA = %11100111
    TRISB = %11000011
    Louie
    Let's look at the code that works. Maybe theres something you left out...
    EN82fn
    The 20-pin version has separate AVSS and AVDD pins.
    Did you connect them to VSS and VDD?
    Feb 2004
    Michigan, USA
    Fixed!
    So it would appear if you use the auto insert serial number feature it changes your config bits during programming. This applies to the U2 programmer software. Uncheck this feature, problem solved, and the design functions just fine.
