Yeah, the problem is that you're not compiling with PBPL.
What version of PBP are you using (you need atleast 2.50 to have LONGs) and are you using MicrocodeStudio or some other IDE or are you compling from the commandline?
I have PicBasic Pro 2.60. I have set all (and work fine whit other sample) in mplabx and MicroCode studio plus, but I have problem with both configuration. Any suggestion?
In MicroCodeStudio, select View -> Compile and Program Options. Then, on the compiler tab make sure that the Use PBPL checkbox is checked - that should be all.
I have no idea how to do it in MPLABX.
Thank you, I had wrong version of MicroCode Studio that not supported the 2.60 version. Now it working but not on MPLAX, I can't remove the mpasmx compiler!
That's great!
Like I said, I don't know how to do it in MPLABX. I have tried to set the bloody thing up but it's so bloody complicated that I've given up - for now.
