Oscilloscope help
Results 1 to 15 of 15
    Nov 2009
    London
    Default Re: Oscilloscope help
    Thanks Darrel, I will try it tomorrow with 16f877A which I have. But I would like to ask if this task can be made possible using a smaller PIC without an HPWM, I would like to use 16F676 if possible as it is very easily available and where I am and if this takes off then it will be economical as well.
    In the mean time I am attaching the datasheet of the Chinese uC which is controlling the base of the NPN transistor connected to the piezo & coil. The signal comes out from PIN 2, which to me seems just an I/O pin.
    Yes, of course it can.
    It's only 3-4 khz. You can generate that in software easily.
    But see if it drives your piezo first.
    I was assumming your piezo has a resonant frequency of ~3.5khz.
    Nov 2009
    London
    Default Smashing results
    THANKS Darrel, it worked like a charm with HPWM. Any pointers as to how to do without it.
    I tried FREQOUT
        FOR Freq = 3000 TO 4000 STEP 10
            FREQOUT PortC.2,1, Freq
        NEXT Freq
    but the results were not the same, not even near enough, the pulsing sound is not that prominent
    Default Re: Smashing results
    FREQOUT makes sine waves and must be filtered, which is not what you need.
    Try this ...
    PiezoPIN  VAR PORTC.2
    TMR0IF    VAR INTCON.2
    Width     VAR BYTE
    OPTION_REG = %11010011 ; TMR0 1:16
    Alarm:
        FOR Width = 161 TO 120 STEP -1
            WHILE !TMR0IF
                TOGGLE PiezoPIN
                PAUSEUS Width
                TOGGLE PiezoPIN
                PAUSEUS Width
            WEND
            TMR0IF = 0
        NEXT Width
    GOTO Alarm
    Nov 2009
    London
    Default Done
    Thanks Darrel and everyone. It's done
    Nov 2009
    London
    Default Without PIC???
    Just out of curiosity, can this be achieved without using a microcontroller?
    Apr 2011
    Default Re: Without PIC???
    Commonly driven by a type 555 multi-function timer chip. Google '555 alarm schematic' and take your pick.
    Also can be done using standard logic gates such as 2-NANDs in astable mode with another 2 providing the modulation therefore a single dual-input quad NAND package (4011 or 7400) will work. You can use NOR gates too.
