Thermostat for refrigerator
Results 1 to 3 of 3
    Dec 2008
    Ploiesti, ROMANIA
    Default Thermostat for refrigerator
    I wrote code for thermostat, with settings of lower und upper threshold...Work fine, but I can not settings those thresholds under 0.0 'C . Under "0.0 'C" (in settings menu, for temp_up & temp_down) on display I have "+655 'C" and minus-button decrease this value ...
    Please, can give someone a hand of help ?! Thanks in advance !
    @ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_ON
    define osc 4
    INTCON	= 0
    include "D:\pbp\alldigital.pbp"
    PORTA.7 = 0
    TRISA= %00100000
    TRISB= %00001111
    CMCON= 7                               	' Disable comparators
    DEFINE LCD_DREG PORTB                  	' LCD on port B
    DEFINE LCD_DBIT 4                      	' Data bits B4..B7
    DEFINE LCD_RSREG PORTA                 	' RS on PORTA
    DEFINE LCD_RSBIT 0                     	' RS on A1
    DEFINE LCD_EREG PORTA                  	' E on PORTA
    DEFINE LCD_EBIT 1                      	' E on A0
    DEFINE LCD_BITS 4                      	' LCD 4 bit mode
    DEFINE LCD_LINES 2                     	' 2 line LCD display
    Define LCD_COMMANDUS 2000               	' Command Delay (uS)
    Define LCD_DATAUS 50                    	' Data Delay (uS)
    Temperature     Var	Word			' Temperature storage
    TempC           Var     Word
    Float           Var     Word
    V	          Var     Word	      	' Var. for display
    Sign		    Var	Byte			' +/- sign
    DQ		    Var     PORTb.3
    Twist           Var     Bit
    Dummy           Var     Byte
    Delay           var     byte
    Mode            VAR     BYTE
    DS18B20_12bit   CON %00111111       	' 0,25°C
    AlarmUp         VAR     BIT
    AlarmDn         VAR     BIT
    B1              Var     Byte   		' Byte for Temp_Up calculation
    B2              Var     Byte   		' Byte for Temp_Up calculation
    B3              Var     Byte
    B4              Var     Byte
    Temp_Up         Var     Word
    Temp_Down       Var     Word
    Read 0, B1                              	' Read Temp_Up MSB
    Read 1, B2                              	' Read Temp_Up LSB
    Temp_Up=B1*256+B2                       	' Calculate Temp_Up value
    Read 2, B3
    Read 3, B4
    Temp_Down= B3*256+B4				' Calculate Temp_Down value
    PORTA.7 = 0
    PORTA.2 = 0                               ' Warm Output Low
    PORTA.3 = 0                               ' Cold Output Low
    Mode = 0                                  ' Temperature display mode
    Pause 500
    LCDOUT $FE, 1, $FE, $0C                 	' Clear display, cursor off
    Pause 100
    ' Init Sensor
     OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
     OWOut DQ, 1, [$CC, $48]       	    	' Start temperature conversion
     OWOut DQ, 1, [$CC, $B8]
     OWOut DQ, 1, [$CC, $BE]
     Pause 50
     OWIn DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]
     Pause 50
    MainLoop:
     If PORTB.0=0 then                      	' Mode switch pressed
      Pause 50                              	' Debounce
    If PORTB.0=0 then MainLoop              	' Wait until button is released
      Mode=Mode+1                           	' Increment mode
    If Mode=2 then                          	' SET Temp_Up
    LcdOut $FE, $80,  "  TEMP_UP  :     "
    LcdOut $FE, $C0, "    ", Sign, DEC (Temp_Up / 100), 223,"C                       "
    	if portb.1=0 then
          Temp_Up=Temp_Up + 100
          Gosub Debounce
    	if portb.2=0 then
          Temp_up=Temp_up - 100
          Gosub Debounce
    EndIf
    If Mode=1 then                          	' SET Temp_Down
    LcdOut $FE, $80,  "  TEMP_DOWN :     "
    LcdOut $FE, $C0, "    ", Sign, DEC (Temp_Down / 100), 223,"C                     "
    	if portb.1=0 then
          Temp_Down=Temp_Down + 100
          Gosub Debounce
    	if portb.2=0 then
          Temp_Down=Temp_Down - 100
          Gosub Debounce
    EndIf
    If Mode > 2 then
    	LCDOUT $FE, $C0, "END      SETTING"
    	PAUSE 1000
       Write 0, Temp_Up / 256			' TargetTemp MSB
    Pause 50
       Write 1, Temp_Up MOD 256             	' TargetTemp LSB
    Pause 50
       Write 2, Temp_Down / 256
    Pause 50
       Write 3, Temp_Down MOD 256
    Pause 50
            mode=0
    EndIf
    If Mode > 0 then Mainloop
    Main :
    PORTA.7 = 0
    if portb.0=0 then Gosub MainLoop
    OWOut DQ, 1, [$CC, $44]
     Pause 760
    WaitLoop:
    While not DQ
    Wend
    Convert_Temp:
    If Temperature.15 then
      Temperature= ~Temperature +1
      Twist = 1
    Endif
    Dummy = 625 * Temperature
    TempC = DIV32 10
    TempC = (Temperature & $7FF) >> 4
    Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
    Temperature = TempC*100 + Float
    If Twist then
      V= 10000 - Temperature                	' 25 C=12500  0 C=10000  -10 C=9000
      Twist = 0
      V= 10000 + Temperature
    EndIf
     GoSub SelectSign                       	' +/blank/- Sign
     GoSub DisplayTemp                      	' Temperature to LCD
     Gosub Checking
    Goto Main
    ' SUBROUTINES:
    SelectSign:
     If v = 10000 then                      	' Temperature = 0 C.
      Sign=" " 						' No sign
     Else
      	If v < 10000 then               	' <> 0
       	Sign="-"					' Temperature below 0 C.
      	Else
       	Sign="+"		        		' Temperature above 0 C.
      	EndIf
     EndIf
    DisplayTemp:
     If V >= 10000 then                     	' Above 0 C.
      Temperature=V-10000
     Else
      Temperature=10000-V                   	' Below 0 C.
     EndIf
    LcdOut $FE, $80,  "TEMP : ",  Sign," ", DEC (Temperature / 100), ".", DEC1 Temperature dig 1  , 223,"C "
    LcdOut $FE, $C0, "DN:",Sign, DEC (Temp_Down / 100), 223, " UP:", Sign, DEC (Temp_Up / 100), 223
    Checking:
     If temperature < Temp_Down then        	' Below Target temperature - Hysteresis
      PORTA.2=1                             	' Activate   Warm Output
        if AlarmDn = 0 then
        sound porta.7, [80, 150]
        low porta.7
        alarmDn = 1
      alarmDn = 0
      Porta.2 = 0
     EndIf
     If Temperature > Temp_Up then          	' Above Target temperature + Hysteresis
      PORTA.3=1                             	' Activate Cold Output
        if AlarmUp = 0 then
        sound porta.7, [110, 150]
        low porta.7
        alarmUp = 1
      alarmUp = 0
      porta.3 = 0
     EndIf
    Debounce :
    For Delay= 1 to 200
    Pause 1
    next Delay
    END       						' Of program
    Default Re: Thermostat for refrigerator
    Normally PBP doesn't handle signed values very well, 1-2=255 so that's probably where the problem is comming from. If you're only displaying values then you can use the SDEC modifier in LCDOUT etc statements, it will give you -1 for the above example. This is only for display purposes though, the actual math operations are still treated as unsigned.
    What to do. Well, you could switch to LONG variables - these are signed. Or you can apply an offset to all your values so that instead of the value 0 meaning 0 degrees you say that 10000 means 0 degrees. 10001 is 0.1 degrees and 9999 is -0.1 degrees - for example.
    I haven't looked very cloesly at your actual code in order to say which would be best.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply ! As usual, I know You are right, but ...
    I trying different variants (applying an offset, like v=10000 + temp_up) ...still no results. I will keep trying ...harder !
