Anyone ever decoded CAN on a PIC?
Results 1 to 3 of 3
    Feb 2005
    Bellevue
    Unhappy Anyone ever decoded CAN on a PIC?
    All:
    Compressed Alphanumeric Code, or CAN code, allows a 16 bit value to represent 3 characters from the set A-Z, 0-9 and the colon, period and dollar sign symbols.
    HEX CAN HEX CAN HEX CAN
    0 0 0
    640 A 28 A 1 A
    C80 B 50 B 2 B
    12C0 C 78 C 3 C
    1900 D A0 D 4 D
    1F40 E C8 E 5 E
    2580 F F0 F 6 F
    2BC0 G 118 G 7 G
    32C0 H 140 H 8 H
    3800 I 168 I 9 I
    3E40 J 190 J A J
    4480 K 1B8 K B K
    4B00 L 1E0 L C L
    5140 M 208 M D M
    5780 N 230 N E N
    5DC0 O 258 O F O
    6400 P 280 P 10 P
    6A40 Q 2A8 Q 11 Q
    7080 R 2D0 R 12 R
    76C0 S 2F8 S 13 S
    7D00 T 320 T 14 T
    8340 U 348 U 15 U
    8980 V 370 V 16 V
    8FC0 W 398 W 17 W
    9600 X 3C0 X 18 X
    9C40 Y 3E8 Y 19 Y
    A280 Z 410 Z 1A Z
    A8C0 0 438 0 1B 0
    AF00 1 460 1 1C 1
    B540 2 488 2 1D 2
    BB80 3 4B0 3 1E 3
    C1C0 4 4D8 4 1F 4
    C800 5 500 5 20 5
    CE40 6 528 6 21 6
    D480 7 550 7 22 7
    DAC0 8 578 8 23 8
    E100 9 5A0 9 24 9
    E740 : 5C8 : 25 :
    ED80 . 5F0 . 26 .
    F3C0 $ 618 $ 27 $
    Sample Conversions For "EVI"
    To convert to CAN code from ASCII, locate the letter in the tables from left to right, and summing the values indicated. For example:
    E = 1F40
    V = 370
    I = 9
    22A9
    To convert from CAN code to ASCII, start with the left most column and locate the largest value that does not exceed the CAN code value. Subtract the indicated value and repeat using the remainder for the second and last columns. For example, given the value #35A5:
    35A5
    -3200 H
    3A5
    -398 W
    D M
    The CAN code value #35A5 results in the letters HWM.
    OK - So, for the really smart ones - can you hint at a structure that can figure that out in PicBasic? I really don't want to load the whole table into memory!!
    I need to take in the CAN code, and return the 3-letter result....
    TG
    EDWARD's Avatar
    EDWARD Guest
    you might what to decode the table in like a visual basic program then copy it into picbasic. those are more powerful for database projects. you can load a txt file as a .dat file into vb6 and sequentially read a set of numbers, perform alg and repeat.
    if im way off sory, i didnt know of CAN.
    i have vb6 progs i made but they only read comma seperated values and im not sure how big your table is and if putting comma in there would be an option.
    or
    is the reason you used CAN so that you could compress your data down? and you need it t reside in the memory, but ascii wouldnt fit? or is it like a learning project?
    Feb 2005
    Bellevue
    Smile Figured out CAN conversion - posting in case anyone ever needs it..
    ' Read the TracID into the 3 letters represented
    16 bits are in SSD1-SSD4:
    SSD4= (ssmax[1]>>4)
    SSD3= (ssmax[1] & $f)
    SSD2= (ssmax[0]>>4)
    SSD1= (ssmax[0] & $f)
    TracID_D=(ssd4*4096)+(ssd3*256)+(ssd2*16)+ssd1 ' convert to dec
    TC1=(TracID_D/1600)
    Select Case TC1
    case 0
    TracID1 = " "
    case TC1 < 27 'A-Z
    TracID1 = TC1 + 64
    case TC1 < 37 '0-9
    TracID1 = TC1 + 21
    case 37
    TracID1 = ":"
    case 38
    TracID1 = "."
    case else
    TracID1 = "$"
    End Select
    t2=TracID_D-(TC1*1600)
    TC2=t2/40
    Select Case TC2
    case 0
    TracID2 = " "
    case TC2 < 27 'A-Z
    TracID2 = TC2 + 64
    case TC2 < 37 '0-9
    TracID2 = TC2 + 21
    case 37
    TracID1 = ":"
    case 38
    TracID1 = "."
    case else
    TracID1 = "$"
    End Select
    TC3=t2-(TC2*40)
    Select Case TC3
    case 0
    TracID3 = " "
    case TC3 < 27 'A-Z
    TracID3 = TC3 + 64
    case TC3 < 37 '0-9
    TracID3 = TC3 + 21
    case 37
    TracID1 = ":"
    case 38
    TracID1 = "."
    case else
    TracID1 = "$"
    End Select
    TracID1, TracID2, TracID3 will be the 3 letters..
    TG
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
