How do you transfer the data from the PIC to the PC?
I'm a bit confused about your math... You say you need 500Kbs (which is quite a bit), but then you say you want 500 measurements per second. With an ADC resolution of 10 bits (each measurement taking two bytes) that's 1000 bytes per second which would be around 100Kbs. Never the less, the bottleneck is probably in the datatransfer itself.
Is it a continous stream of samples or is it a defined amount of samples at a certain sample rate or what exactly are you trying to do. The 4550 has 2k of ram so depending on what else your program is doing you might be able to store the samples in RAM and then transfer them to the PC - but again, it all depends on what you're doing.
