Can someone please provide a proteus module for DAC ??
Results 1 to 10 of 10
    Mar 2006
    China
    Default Re: Can someone please provide a proteus module for DAC ??
    I dont use sims either but why dont you connect a signal generator and feed the signal to an
    --R --- R ---
    C C
    GND
    low pass filter and after that you should have a DC level that adjusted by the amplitude from the signal generator. If you use PWM signal it should be linear.
    Jan 2010
    Thanks jumper, what you are saying is at a much higher level than I can understand. I really would like someone with expertise in proteus to help me.
    Jan 2010
    I tried with DAC_10 device under Modelling Primitives, I don't know if I am doing it right, but I connected D0-9 bus to 10 dip switch array. VRef+ to +5V and - to Gnd. Changing the DIP switch position is not changing the output voltage, which is staying as constant 0V. I tried connecting LE pin to +ve & ground both but no luck.
    Did you label the blue bus (just outside the chip) with d[0..9], and label all the individual lines from the dip switch that go to the blue bus ( d0, d1 ...)
    http://www.scalerobotics.com
    Here's an example that gives two 12-bit analog voltages using a DAC.
    A Virtual Terminal is used to set the voltages.
    http://support.melabs.com/threads/28...replaces-pots)
