ok, i modified the cod to use a temporary byte variable in ram and then write the var to LATB as follows...
TEMPPORTC VAR BYTE
BAT1BLEED VAR TEMPPORTC.7
BAT1BLEEDIND VAR TEMPPORTC.6
BAT2BLEED VAR TEMPPORTC.5
BAT2BLEEDIND VAR TEMPPORTC.4
ALARM VAR TEMPPORTC.3
IF BAT2TEMP > BAT1TEMP+5 THEN
    BAT2BLEED = 1
    BAT2BLEEDIND = 1
    BAT1BLEED = 0
    BAT1BLEEDIND = 0
    BAT2BLEEDCOUNT = 0
    LATB = TEMPPORTC
for diagnostics i modified the LCD command to the following...
LCDOUT $FE, $80, DEC4 BAT1TEMP, " ", DEC4 BAT2TEMP, " "
IF BAT1TEMP > BAT2TEMP THEN
    LCDOUT DEC4 (BAT1TEMP - BAT2TEMP), " "
    LCDOUT DEC4 (BAT2TEMP - BAT1TEMP), " "
LCDOUT $FE, $C0, BIN8 TEMPPORTC
the second line on the LCD reads
But, again, only the ALARM LED is on...
So, the temp var is correct, but it's not setting to port correctly????
