OK, been trying to figure this out for over a week now...
I'm trying to create a charge controller/balancer for LI-POL / LI-ION battery packs.
I started with the 16F1824 but it was doing weird things so i switched to an 18F46K22 and hooked up an LCD for diagnostics.
I even tried two known working 18K46K22's just incase it was a damaged chip.
The circuit at the moment is simple. 2 LI-IONs (for testing) linked in series. 5V supply to PIC and LCD VIA L7805CV fed from both battery's in series.
AN0 is the combined voltage from both cells via a 4:1 voltage divider (3K and 1K)
AN1 is the voltage between the two cells via a 2:1 voltage divider (1K and 1K)
The LCD gives me the analogue conversion values and the difference between them. This works perfectly
Atm, all outputs just have LED's hung on them for diagnostics.
I moved the outputs fro PORTC to PORTB and it's still doing the same thing...
When it executed "PORTB = 255" then all the LED's come on as they should.
BUT when i say,
BAT1BLEED = 1
BAT1BLEEDIND = 1
BAT2BLEED = 1
BAT2BLEEDIND = 1
ALARM = 1
Then only the BAT2BLEEDIND LED comes on.
I don't think i have done something stupid, but i'd appreciate another pair of eyes.
Code:@ __config _CONFIG1H, _FOSC_INTIO67_1H & _PLLCFG_ON_1H & _PRICLKEN_ON_1H & _FCMEN_ON_1H & _IESO_ON_1H @ __config _CONFIG2L, _PWRTEN_ON_2L & _BOREN_OFF_2L & _BORV_220_2L @ __config _CONFIG2H, _WDTEN_ON_2H & _WDTPS_32768_2H @ __config _CONFIG3H, _CCP2MX_PORTC1_3H & _PBADEN_OFF_3H & _CCP3MX_PORTE0_3H & _HFOFST_OFF_3H & _MCLRE_INTMCLR_3H @ __config _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L @ __config _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L @ __config _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H @ __config _CONFIG6L, _WRT0_OFF_6L @ __config _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H @ __config _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L @ __config _CONFIG7H, _EBTRB_OFF_7H INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler AD_INT, _ADC_HANDLER, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM DEFINE LCD_DREG PORTD ' LCD data port DEFINE LCD_DBIT 0 ' LCD data starting bit 0 or 4 DEFINE LCD_RSREG PORTE ' LCD register select port DEFINE LCD_RSBIT 0 ' LCD register select bit DEFINE LCD_EREG PORTE ' LCD enable port DEFINE LCD_EBIT 2 ' LCD enable bit DEFINE LCD_RWREG PORTE ' LCD read/write port DEFINE LCD_RWBIT 1 ' LCD read/write bit DEFINE LCD_BITS 8 ' LCD bus size 4 or 8 data bits DEFINE LCD_LINES 2 ' Number lines on LCD DEFINE LCD_COMMANDUS 2000 ' LCD Command delay time in us DEFINE LCD_DATAUS 50 ' LCD Data delay time in us Define OSC 64 ' Set clock speed OSCCON = %01110000 OSCTUNE.6 = 1 ;PLL enable ANSELA = %11111111 ANSELB = %00000000 ANSELC = %00000000 ANSELD = %00000000 ANSELE = %00000000 TRISA = %11111111 TRISB = 0 TRISC = 0 PORTC = 0 TRISD = 0 PORTD = 0 TRISE = 0 PORTE = 0 CHAN VAR BIT BAT1 VAR WORD BAT2 VAR WORD BAT1TEMP VAR WORD BAT2TEMP VAR WORD TEMPWORD VAR WORD VALIDBATDATA VAR BIT BAT1BLEEDCOUNT VAR WORD BAT2BLEEDCOUNT VAR WORD ALOOP VAR BYTE BAT1BLEED VAR PORTB.7 BAT1BLEEDIND VAR PORTB.6 BAT2BLEED VAR PORTB.5 BAT2BLEEDIND VAR PORTB.4 ALARM VAR PORTB.3 LCDOUT $FE, 1, "INITIALISING" PORTB = 255 PAUSE 1000 PORTB = 0 PAUSE 1000 BAT1BLEED = 1 BAT1BLEEDIND = 1 BAT2BLEED = 1 BAT2BLEEDIND = 1 ALARM = 1 PAUSE 1000 BAT1BLEED = 0 BAT1BLEEDIND = 0 BAT2BLEED = 0 BAT2BLEEDIND = 0 ALARM = 0 PAUSE 1000 BAT1BLEED = 1 BAT1BLEEDIND = 1 BAT2BLEED = 1 BAT2BLEEDIND = 1 ALARM = 1 PAUSE 1000 BAT1BLEED = 0 BAT1BLEEDIND = 0 BAT2BLEED = 0 BAT2BLEEDIND = 0 ALARM = 0 PAUSE 1000 BAT1BLEED = 1 BAT1BLEEDIND = 1 BAT2BLEED = 1 BAT2BLEEDIND = 1 ALARM = 1 PAUSE 1000 BAT1BLEED = 0 BAT1BLEEDIND = 0 BAT2BLEED = 0 BAT2BLEEDIND = 0 ALARM = 0 PAUSE 1000 BAT1BLEED = 1 BAT1BLEEDIND = 1 BAT2BLEED = 1 BAT2BLEEDIND = 1 ALARM = 1 PAUSE 1000 BAT1BLEED = 0 BAT1BLEEDIND = 0 BAT2BLEED = 0 BAT2BLEEDIND = 0 ALARM = 0 CLEAR @ INT_ENABLE AD_INT ADCON2 = %10111110 ADCON1 = %00000000 ADCON0 = %00000011 LCDOUT $FE, 1 MAIN: BAT1TEMP = BAT1 BAT2TEMP = BAT2 LCDOUT $FE, $80, DEC4 BAT1TEMP, " ", DEC4 BAT2TEMP, " " IF BAT1TEMP > BAT2TEMP THEN LCDOUT DEC4 (BAT1TEMP - BAT2TEMP), " " ELSE LCDOUT DEC4 (BAT2TEMP - BAT1TEMP), " " ENDIF IF BAT2TEMP > BAT1TEMP+5 THEN BAT2BLEED = 1 BAT2BLEEDIND = 1 BAT1BLEED = 0 BAT1BLEEDIND = 0 BAT2BLEEDCOUNT = 0 ELSE IF BAT2BLEEDCOUNT = 100 THEN BAT2BLEED = 0 BAT2BLEEDIND = 0 BAT2BLEEDCOUNT = 0 ELSE BAT2BLEEDCOUNT = BAT2BLEEDCOUNT + 1 ENDIF ENDIF IF BAT1TEMP > BAT2TEMP+5 THEN BAT1BLEED = 1 BAT1BLEEDIND = 1 BAT2BLEED = 0 BAT2BLEEDIND = 0 BAT1BLEEDCOUNT = 0 ELSE IF BAT1BLEEDCOUNT = 100 THEN BAT1BLEED = 0 BAT1BLEEDIND = 0 BAT1BLEEDCOUNT = 0 ELSE BAT1BLEEDCOUNT = BAT1BLEEDCOUNT + 1 ENDIF ENDIF ;IF BAT1 > 819 THEN ; BAT1BLEED = 1 ; PORTC.1 = 1 ; BAT1BLEEDIND = 1 ; BAT2BLEEDIND = 1 ; PORTC.2 = 1 ; ELSE ; PORTC.2 = 0 ; BAT1BLEEDIND = 0 ; BAT2BLEEDIND = 0 ;ENDIF ;IF BAT1 < 614 THEN ; BAT1BLEED = 0 ; PORTC.0 = 0 ; BAT2BLEED = 0 ; BAT1BLEEDIND = 1 ; BAT2BLEEDIND = 1 ; ELSE ; PORTC.2 = 0 ; BAT1BLEEDIND = 0 ; BAT2BLEEDIND = 0 ;ENDIF GOTO MAIN ADC_HANDLER: TEMPWORD.LOWBYTE = ADRESL TEMPWORD.HIGHBYTE = ADRESH IF CHAN = 0 THEN ADCON0 = %00000111 BAT1 = TEMPWORD CHAN = 1 @ INT_RETURN ENDIF IF CHAN = 1 THEN ADCON0 = %00000011 BAT2 = TEMPWORD CHAN = 0 @ INT_RETURN ENDIF @ INT_RETURN
