16f887 to 18f4685 transition
Results 1 to 23 of 23
    Dec 2010
    Default Re: 16f887 to 18f4685 transition
    The code does compile 100% no errors, but it runs improperly. I am getting scrambled characters from the HSERIN/HSEROUT commands when the program is on the 18f4685, but when the program is on the 16f887 it works perfectly.
    Here is how I have the 16f887 initialized (I did not use any config settings here)
    Define device 16F887
    Define OSC 8
    ANSEL=0 ' A/D disabled for ANS0 to ANS7
    ANSELH=0 ' A/D disabled for ANS8 to ANS13
    CM1CON0 = 0 ' Disable comparators
    CM2CON0 = 0 ' These default to disabled at POR, but just in case
    CM2CON1 = 0
    ADCON1 = 7
    IOCB = 0
    INTCON = 0
    DEFINE HSER_RCSTA 90h ' Enable Serial PORT
    DEFINE HSER_TXSTA 24h ' Enable transmit
    DEFINE HSER_SPBRG 129 ' set USART to 9600 baud (when BRGH=1)
    DEFINE HSER_CLROERR 1 ' Enable automatic overrun error
    DEFINE LOADER_USED 1
    and this is how the 18f4685 is initialized
    define device 18f4685
    @ __CONFIG    _CONFIG1H, _OSC_IRCIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    @ __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @ __CONFIG    _CONFIG4L,  _STVREN_ON_4L & _LVP_OFF_4L & _BBSIZ_1024_4L & _XINST_OFF_4L
    OSCTUNE = %11000000
    OSCCON = %01110000
    define OSC 8
    CMCON = 0
    ADCON0 = 7
    ADCON1 = 7
    ADRESH = %00000000
    ADRESL = %00000000
    INTCON = 0
    INTCON2 = 0
    INTCON3 = 0
    IPR1 = 0
    PIR1 = 0
    PIE1 = 0
    The rest of the program has remained unchanged.
    Set
    OSCTUNE = %00000000
    And try this
    DEFINE HSER_SPBRG 51  ' 9600 Baud @ 8MHz, 0.16%
    SPBRGH = 0
    Dec 2010
    these changes make it so the only symbol transmitted the "≡" symbol instead of receiving mixed characters and symbols
    I think it is time to provide your code and schematic.
    Dec 2010
    I'll have to explain some things about the program. The project is a text-based video game system designed around multiple slave PICs and a master PIC, which communicates between both the console slave chips and game cartridge master/slave chips. The first chip to send serial data to the consoles master chip, is the console title chip. The data is then sent from the console master chip to a product called the Tellymate, which converts serial data to composite video based on hexadecimal characters from code page 437.
    Links:
    Tellymate - http://www.batsocks.co.uk/products/O...0TTL%20Kit.htm
    Code Page 437 - http://en.wikipedia.org/wiki/Code_page_437
    Like I said before, when this program is on the 16f887, it works flawlessly.
    'Define device 16F887
    'Define OSC 8
    'ANSEL=0 ' A/D disabled for ANS0 to ANS7
    'ANSELH=0 ' A/D disabled for ANS8 to ANS13
    'CM1CON0 = 0 ' Disable comparators
    'CM2CON0 = 0 ' These default to disabled at POR, but just in case
    'CM2CON1 = 0
    'ADCON1 = 7
    'IOCB = 0
    'INTCON = 0
    OSCTUNE = %00000000
    OSCCON = %01110000
    define OSC 8
    CMCON = 0
    ADCON0 = 7
    ADCON1 = 7
    ADRESH = %00000000
    ADRESL = %00000000
    INTCON = 0
    INTCON2 = 0
    INTCON3 = 0
    IPR1 = 0
    PIR1 = 0
    PIE1 = 0
    SPBRGH = 0
    'DEFINE HSER_RCSTA 90h ' Enable Serial PORT
    'DEFINE HSER_TXSTA 24h ' Enable transmit
    'DEFINE HSER_SPBRG 129 ' set USART to 9600 baud (when BRGH=1)
    'DEFINE HSER_CLROERR 1 ' Enable automatic overrun error
    ''DEFINE LOADER_USED 1
    '~~~~~Variables~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                           '~~~~~Slave Chip~~~~~
    Cart_Audio  var portc.0   'Switch 1AB
    Cart_Title var portc.1   'Switch 1CD
    Audio      var portc.2   'Switch 2AB
    Keyboard   var portc.3   'Switch 2CD
    TellyMate  var portd.0   'Switch 3AB
    Slaves     var portd.1   'Switch 3CD
    Title      var portd.2   'Switch 4AB
    Cart_Master  var portd.3   'Switch 4CD
    CNT var byte
    CNT2 var byte
    SerDat var byte
    MasterTrig var portd.4   'chip sensor pin
    MasterCheck var bit
    Master_Busy var porte.0  'timing pin
    AudioTrig var portd.5    'chip sensor pin
    TitleTrig var portd.6    'chip sensor pin
    Assign_Var var byte
    Key_Var var byte
    Letter_CNT var byte
     B1 var byte
     B2 var byte
     B3 var byte
     B4 var byte
     B5 var byte
     B6 var byte
     B7 var byte
     B8 var byte
     B9 var byte
     B10 var byte
     B11 var byte
     B12 var byte
     B13 var byte
     B14 var byte
     B15 var byte
     B16 var byte
     B17 var byte
     B18 var byte
     B19 var byte
     B20 var byte
     B21 var byte
     B22 var byte
     B23 var byte
     B24 var byte
     B25 var byte
    '~~~~~Initialize TextBox~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    trisc.0 = 0
    trisc.1 = 0    'make all SLAVE pins OUTPUTS
    trisc.2 = 0
    trisc.3 = 0
    trisd.0 = 0
    trisd.1 = 0
    trisd.2 = 0
    trisd.3 = 0
    trisd.4 = 1    'make Master_Trigger INPUT
    trisd.5 = 1    'make Audio_Trigger INPUT
    trisd.6 = 1    'make Title_Trigger INPUT
    trise.0 = 1    'make Master_Busy INPUT
    cart_audio = 0
    Cart_title = 0
    Audio = 0       'ALL Slaves set to
    keyboard = 0    'no communication
    tellymate = 0  'Motherchip to Tellymate
    Slaves = 0     'Slave chips to Motherchip
    title = 0
    cart_master = 0
    pause 30
    '~~~~~AutoBaud~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    AutoBaud:
    tellymate = 1
    pause 30       'mandatory 30ms pause for 4066 switching
    hserout ["U", $1B, $45]  'transmit autobauding character, clear screen and return home
    hserout [$1B, $76]       'allow text to continue on next line
    'hserout [$1B, $66]       'CURSOR OFF
    tellymate = 0
    pause 30
    mastercheck = 0
    cnt = 0
    '~~~~~Program Start~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Start:
    audio = 0
    cart_audio = 1
    GOTO LOAD_CARTRIDGE
    slaves = 1  'allow slave communications
    audio = 1   'enable audio communications
    pause 30
     hserout [0]   'play Intro sound file
     pause 50
     audio = 0  'disable audio communications
     pause 30
    title = 1  'enable TITLE SCREEN communications
    tellymate = 1
    pause 30
    repeat
     hserin [serdat]    'display TEXTBOX TITLE SCREEN
     hserout [serdat]
    until serdat = $BC  'last command sent by CARTRIDGE TITLE
    pause 10  'allow SerDat to display everything
    title = 0 'disable TITLE SCREEN communications
    tellymate = 0
    'pause 30
    pause 1700
    'Main:
    'keyboard = 1         'enable typing
    'pause 30
    'hserin [serdat]      'receive keyboard data
    'if serdat = $0D then 'IF RETURN has been pressed
    ' slaves = 0           'disable slave communications
    ' keyboard = 0         'disable typing
    ' pause 30            'and access boot menu
    ' hserout [$1B, $45]  'clear screen and cursor to 0,0
    ' goto cartridge_check
    'else
    ' goto main     'repeat until RETURN is pressed
    'endif
    '~~~~~Cartridge Check~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Cartridge_Check:
    tellymate = 1  'enable Motherchip to TellyMate communications
    pause 30
    hserout [$1B, $45]
    HSEROUT [$1B, $65]  'CURSOR ON
    gosub next_line
    hserout ["Checking Cartridge Port.", $0D, $0A, "Do Not Add/Remove Cartridge/"]
    if mastertrig = 1 then  'IF portd.4 = 1, THEN
     mastercheck = 1        'cartridge is there
     mastercheck = 0        'cartridge is missing
    gosub loading_dots
    gosub next_line
    gosub next_line
    'if cartridge is there and hasn't been removed~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    if mastertrig = 1 and mastercheck = 1 then
     gosub next_line
     hserout ["Cartridge Found.", $0D, $0A, "Loading Cartridge Data/"]
     Gosub Loading_dots
     gosub next_line
     gosub next_line
     pause 200
     hserout [$1B, $66]      'CURCOR OFF
     hserout [$20, $F9, "Master Chip Located/", $0D, $0A]
     pause 15
     if audiotrig = 1 then
      hserout [$20, $F9, "Audio Chip Located/", $0D, $0A]
     pause 15
     if titletrig = 1 then
      hserout [$20, $F9, "Title Chip Located/", $0D, $0A]
     pause 15
     gosub next_line
     gosub next_line
     hserout [$1B, $59, 50, 34, $AF, $AF, "Press Return To Load Cartridge", $AE, $AE]
     pause 10
     tellymate = 0
     pause 30
    Cart_Loop:
     slaves = 1
     keyboard = 1
     serdat = 0
     repeat
      hserin [serdat]
     until serdat != 0
      slaves = 0
      keyboard = 0
      goto load_cartridge
      goto cart_loop
    'if cartridge is missing and hasn't been added~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    if mastertrig = 0 and mastercheck = 0 then
     gosub next_line
     hserout ["No Cartridge Was Found.", $0D, $0A, "Loading Text Editor/"]
     gosub loading_dots
     gosub next_line
     gosub next_line
     hserout [$1B, $66, $1B, $45]
     gosub next_line
     hserout [$1B, $59, 33, 44, $AF, $AF, "Text Editor", $AE, $AE]
     gosub next_line
     gosub next_line
     hserout [$1B, $65]
     gosub text_editor
    'if cartridge was removed while loading~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    if mastertrig = 1 and mastercheck = 0 then
     gosub cart_error
    'if cartridge was inserted while loading~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    if mastertrig = 0 and mastercheck = 1 then
     gosub cart_error
    '~~~~~Text Editor~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Text_Editor:
     pause 30
     Text_Editor_Loop:
     hserin [serdat]    'receive data from Keyboard
     hserout [serdat]   'then display it
    goto text_editor_loop
    '~~~~~Subroutines~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Cart_Error:
     slaves = 1
     audio = 1
     pause 30
     hserout [2]
     pause 50
     audio = 0
     pause 30
     hserout ["Error/"]
     slaves = 0
     audio = 0
     pause 500              'reset to Cartridge_Check
     gosub next_line
     gosub next_line
    Loading_Dots:
     hserout ["."]
     hserout ["."]   'just some dots
     hserout ["."]
    Next_Line:
     hserout [$0D, $0A]     'jump to column 0 of next row
    '~~~~~Load Cartridge~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Load_Cartridge:
    if audiotrig = 1 then    'if AUDIO chip is in CARTRIDGE
     cart_audio = 1   'enable audio communications
     pause 30
     hserout [1]   'play Intro Cartridge sound file
     pause 50
     cart_audio = 0  'disable audio communications
     pause 30
    if titletrig = 1 then    'if TITLE chip is in CARTRIDGE
     tellymate = 1
     cart_title = 1          'show title
     pause 30
    'pause 30
    Load_Cartridge_Loop:
    repeat
     hserin [serdat]   'receive data from Cartridge
    until serdat = $BC  'last character of Cartridge Title Screen
    pause 30
    cart_title = 0
    cart_audio = 0
    pause 5000
    pause 30
    'goto menu
    '~~~~~Menu~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Menu:
    'tellymate = 1
    cart_master = 0           'close master_chip communications
    while master_busy = 1     'wait until master chip is finished working
    'hserout ["."]
     goto menu                'repeat until master_chip is done
    wend
    tellymate = 0    'disable text on screen
    serdat = 0       'unassigned value for Menu loop
    slaves = 1       'enable slave communications
    cart_master = 1  'enable master_chip communications
    repeat
     hserin [serdat]     'receive subroutine number to execute
    until serdat != 0    'wait to receive command
    select case serdat          'read subroutine number
     case $31 '1
      goto Master_screen_loop   'if serdat = 1
     case $32 '2
      goto no_text_keyboard     'if serdat = 2
     case $33 '3
      goto keyboard_loop    'if serdat = 3
    end select
    goto menu
    '~~~~~Master_Screen_Loop~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Master_Screen_Loop:            'display first/next screen of game
    'hserout [$1B, $45]   'clear text from current screen
    tellymate = 1        'enable text on screen
    repeat
     hserin [serdat]     'receive screen character from game
     hserout [serdat]    'and display it on screen
    until serdat = $00   'until terminate command is sent
    tellymate = 0
    goto menu
    '~~~~~No_Text_Keyboard~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    No_Text_Keyboard:   'keyboard/cartridge transactions
    tellymate = 0       'without text on screen
    goto key_assignment
    Key_Assignment:
    cnt2 = 0        'assigned letter count variable
    Letter_CNT = 0  'assigned letter quantity
    serdat = 0
    '~~~~~Receive Letter_CNT character amount~~~~~
    cart_master = 1  'enable Cart_Master communications
    repeat
     hserin [letter_cnt]   'receive letter amount
     pauseus 14
    ' tellymate = 1
    ' hserout ["Letter_CNT = ", dec letter_cnt]  'display letter amount
    until letter_cnt >= 1 and letter_cnt <= 25
    '~~~~~Receive Corresponding Characters~~~~~
    'slaves = 1       'enable slave communications
    'cart_master = 1  'enable Cart_Master communications
    cnt2 = 0
    'pause 30
    repeat
     hserin [serdat]   'receive letter variable
     pauseus 14
    ' tellymate = 1
    ' hserout [serdat]
     write cnt2, serdat  'and store in EEPROM 0-24
     cnt2 = cnt2 + 1
    until cnt2 = letter_cnt   'until CNT2 equals letter amount
    cart_master = 0
    pause 30
    cnt2 = 0                  'reset CNT2 value
    '~~~~~Keyboard_Loop~~~~~~~~~~~~~~~~~~~~~~~~
    Keyboard_Loop:
    'tellymate = 0
    serdat = 0                'reset SerDat value
    repeat                    'repeat
     cart_master = 0          'disabling cart_master communications
     keyboard = 1             'enabling keyboard communications
     hserin [serdat]          'and receiving data from the keyboard
    until serdat != 0
                              'then
     keyboard = 0             'disabling keyboard communications
     cart_master = 1          'enabling cart_master communications
     hserout [serdat]         'and sending keyboard data to cartridge
    repeat
     read cnt2, key_var   'save CNT2 value (EEPROM location) to Key_Var
    select case serdat    'and compare Key_Var to keyboard input
    '  case $0D             'if keyboard = ENTER
    '   goto menu
      case key_var         'if keyboard = requested character
       goto menu
    '  case else            'if keyboard = anything else
    '   cnt2 = cnt2 + 1          'add 1 to CNT2
    '  goto keyboard_loop
     end select
     cnt2 = cnt2 + 1
    until cnt2 >= letter_cnt   'until all requested letters
    cnt2 = 0                  'have been scanned
    goto keyboard_loop
    '~~~~~Yes_Text_Keyboard~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    Yes_Text_Keyboard:      'keyboard/cartridge transactions
                            'with text on screen
    tellymate = 1
    goto key_assignment
    And here is the data sent from the Title chip, which is a 16f688.
    Define device 16F688
    Define OSC 8
    'CM2CON1 = 0
    CMCON0 = 0
    ADCON1 = 7
    'IOCB = 0
    'INTCON = 0
    '~~~~~Variables~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~`
    SerDat var byte
    Trigger var portc.3
    trisc.3 = 1
    '~~~~~Start-up Screen~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    if trigger = 1 then
    if trigger = 1 then
    'Use command "$1B, $59 to place cursor, and
    'add (cursor location +32) for command coordinates
    HSEROUT [$1B, $66]  'CURSOR OFF
             '1                   5                        10                       15                       20                       25                       30                       35             38
    hserout [$C9, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $BB]
    HSEROUT [$BA, $DE, $DC, " ", " ", $DB, $DC, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $DC, $DC, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $BA]
    HSEROUT [$BA, " ", $DB, $DB, $DB, $DB, $DB, $DB, $DC, $DC, " ", " ", " ", " ", " ", " ", " ", " ", $DC, " ", " ", $DB, $DF, $DF, $DD, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $BA]
    HSEROUT [$BA, " ", " ", " ", " ", $DB, $DD, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $DB, " ",  " ",$DE, " ", " ", $DE, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $BA]
    HSEROUT [$BA, " ", " ", " ", $DE, $DB, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $DE, $DF, $DB, $DF, $DD, $DE, $DB, $DB, $DD, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $BA]
    HSEROUT [$BA, " ", " ", " ", $DB, $DD, " ", $DC, $DC, $DC, " ", $DE, " ", " ", " ", $DC, " ", " ", $DB, " ", " ", $DE,  " ", " ",$DE, " ", $DE, $DC, $DC, $DC, " ", $DE, " ", " ", " ", $DC, " ", $BA]
    HSEROUT [$BA, " ", $DD, $DE, $DB, " ", $DE, " ", " ", " ", $DD, " ", $DF, $DC, $DF, " ", " ", " ", $DB, " ", " ", $DE, " ", " ", " ", $DD, $DE, " ", " ", $DD, " ", " ", $DF, $DC, $DF, " ", " ", $BA]
    HSEROUT [$BA, $DE, $DD, $DB, $DD, " ", $DB, $DF, $DF, $DF, " ", " ", $DC, $DF, $DC, " ", $DE, $DE, $DD, " ", " ", $DB, " ", " ", " ", $DD, $DD, " ", " ", $DE, " ", " ", $DC, $DF, $DC, " ", " ", $BA]
    HSEROUT [$BA, " ", $DF, $DF, " ", " ", " ", $DF, $DF, $DF, " ", $DF, " ", " ", " ", $DF, " ", $DF, " ", " ", $DF, $DF, $DF, $DF, $DF, " ", $DF, $DF, $DF, $DF, " ", $DF, " ", " ", " ", $DF, " ", $BA]
    HSEROUT [$CC, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $B9]
    HSEROUT [$BA, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $BA]
    hserout [$BA, "P", "o", "w", "e", "r", "e", "d", " ", "B", "y", ":", " ", " ", $DC, $DC, $DC, " ", " ", " ", " ", " ", " ", $DE, " ", $DE, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $BA]
    HSEROUT [$BA, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $DB, " ", $DC, " ", " ", " ", " ", " ", $DE, $DD, $DB, " ", $DC, " ", " ", $DC, " ", " ", $DC, " ", " ", " ", $BA]
    HSEROUT [$BA, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $DB, $DE, $DC, $DD, $DD, $DD, $DD, $DD, $DE, $DE, $DE, $DE, $DC, $DD, $DF, $DB, $DF, $DE, $DC, $DD, " ", " ", $BA]
    HSEROUT [$BA, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $DB, $DE, $DC, " ", $DD, $DD, $DE, " ", $DE, " ", $DE, $DE, " ", $DD, " ", $DB, " ", $DE, $DC, " ", " ", " ", $BA]
    HSEROUT [$BA, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", "T", "M", $BA]
    HSEROUT [$BA, " ", " ", "A Product of www.Batsocks.co.uk", " ", " ", " ", $BA]
    hserout [$CC, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $B9]
    HSEROUT [$BA, " ", "Circuit Design and Programming By:", " ", $BA]
    hserout [$ba, " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", " ", $BA]
    hserout [$BA, " ", " ", " ", " ", " ", " ", "Robby Hannan, March 2012", " ", " ", " ", " ", " ", " ", $BA]
    HSEROUT [$C8, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $CD, $BC]
    hserout [$00]
    endif                     'Change line 75 PAUSE time to length of picture scroll + music
    Is the 18f4685 connected to the TellyMate with the same hardware as the 16f887 was?
    Sorry that I am not able to spot the problem right off.
    Dec 2010
    hey no need to apologize, but yes, the 18f4685 is attached to the same hardware as the 16f887. I chose the 18f4685 because it had an identical pinout to the 16f887 so all I would have to do is swap the chips on my breadboard. I would provide a schematic if I had one but I can't draw one up in multisim.
