I am using MPASM v5.1 with Processor, Radix, Warning Level, Macro Expansion, and Hex Output set to default;
Generated File has Error and List files selected; Case Sensitive is also selected.
Are those what you meany by the configuration settings?
No, I mean these.
No, I don't have anything nor have ever used anything like that before to my knowledge. I looked into the devices folder within my MPASM installation and I didn't see it in the list. Could that be why it isn't working?
You have never set the configuration for any chip? Not even changed the type of oscillator used? The *.inc file that needs changed is in the PBP directory.
Read through the thread I linked you too, figure out where all f the files are, then we can go from there.
Alright. I was able to find the .INC file and found the config bits at the bottom of the page. I came up with this so far but it doesn't work yet. Whenever I compile my program in MCS it gives me an error message for the "&" symbols.
And no I've never used this method before. I guess I've always gotten away with what I showed you in the initial post (until now), although now it seems incorrect.Code:@__CONIG_OSC_IRCIO67_1H &_FCMEN_OFF_1H &_PWRT_OFF_2L &_BOREN_OFF_2L &_WDT_OFF_2H &_MCLRE_ON_3H &_LVP_OFF_4L
Goto the *.inc file in the PBP directory and comment out the config lines so it looks like this:
Then in your code;Code:;**************************************************************** ;* 18F4685.INC * ;* * ;* By : Leonard Zerman, Jeff Schmoyer * ;* Notice : Copyright (c) 2008 microEngineering Labs, Inc. * ;* All Rights Reserved * ;* Date : 09/15/08 * ;* Version : 2.60 * ;* Notes : * ;**************************************************************** NOLIST ifdef PM_USED LIST "Error: PM does not support this device. Use MPASM." NOLIST else LIST LIST p = 18F4685, r = dec, w = -311, w = -230, f = inhx32 INCLUDE "P18F4685.INC" ; MPASM Header ; __CONFIG _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H ; __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H ; __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H ; __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _BBSIZ_1024_4L & _XINST_OFF_4L NOLIST endif LIST EEPROM_START EQU 0F00000h BLOCK_SIZE EQU 64
Code:'18F4685 TEST @ __CONFIG _CONFIG1H, OSC_IRCIO67_1H & _FCMEN_OFF_1H & _IESO_OFF_1H @ __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H @ __CONFIG _CONFIG3H, _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _BBSIZ_1024_4L & _XINST_OFF_4L
I'm sorry but that didn't seem to work either, but I have a few questions now. The WDT, was that set to 512 to somehow complement the 8MHz oscillation speed? Also this config line:
Does this let the chip change variable values while it's running or does it allow the chip to add code (a FOR...NEXT loop for example) to itself while in operation?Code:_BBSIZ_1024_4L
By the way, thanks for the time and help thus far
