TMR1 issue
Results 1 to 7 of 7
Thread: TMR1 issue
    Default Re: TMR1 issue
    The datasheet says not to set ADON and GO/DONE bits at the same time. I don't know why and I'd guess it's got nothing to do with the problem but you never know. First set up and turn on the ADC in your initialisation, then flip the GO/DONE bit (ADCON0.1 = 1) when you want to start a conversion.
    Your comments in the code says the pot input is on GP1. The code does not set GP1 to input and does not set GP1 to analog. In a previous message though you said you had moved the pot input from GP1 to GP0 (which matches the TRIS and ANSEL setting) but if so it looks like your trying to sample the wrong input because ADCON0=%00000111 would sample GP1.
    You also seams to have CM-/GP1/AN1 configured as input to the comparator - don't know if that may present a problem.
    Well, not much concrete but atleast something to look into. I'd probably try getting the ADC running outside the interrupts to begin with it. Start it, poll the interrupt flag, get the result (or even use ADCIN for that matter). Then, when that works move it to interrupts.
    BTW, you're currently trying to sample as fast as it can possible go. As soon as one conversion is done and serviced you start the next. You'll spend a lot of time jumping in and out of the AD interrupt routine that way and the value doesn't get used untill the timer overflows. Since the timer is only reloaded when it overflows why not sample the pot in the timer interrupt as well?
    Apr 2012
    Leicester UK
    Success!
    Henrik Thank you very much for your assistance. It looks like I need to spend more time and effort looking at and analysing my configuration registers. Though as you suggested it appears that if I set the various interrupt registers (INTCON and PIE1) you do not need the @ INT_ENABLE TMR1_INT and @ INT_ENABLE AD_INT lines (commented out below), maybe Darrel could shed some light on this? Though I must thank him for the DT-Ints code as it does appear to be excellent piece of code.
    To confirm I initially intended to have the analogue attached to AN0 but moved it to AN1 due to realising that I could not have CMCON0 (bits 2-0) set that AN0 as an analogue input and GPIO.1 as a digital input and output. so I swapped them around and unfortunately didn't swap all of the settings in the configuration registers that I should have done.
    I have attached the working code below for anyone to reference in the future.
    clear
    DEFINE OSC 8
    'GP0 LED OUT
    'GP1 AD1 FOR POT INPUT
    'GP2 LED STATUS
    'GP5 LED STATUS 1
    'REGISTERS
    OPTION_REG = %11000000
    INTCON = %11000000
    PIE1 = %01000001
    PIR1 = %00000000
    OSCCON = %01110001
    TRISIO = %00000010
    ANSEL = %00100010
    CCP1CON = %00000000
    CMCON0 = %00000100
    ADCON0 = %00000101
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    'wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    'OUTPUT PINS
    LEDOut VAR GPIO.0
    LEDStatus VAR GPIO.2
    LEDStatus1 var GPIO.5
    high ledstatus
    low ledstatus
    high ledstatus
    low ledstatus
    T1CON = %00110001
    'VARIABLES
    LENGTH VAR WORD
    PauseA var byte
    PASS var byte
            INT_Handler    TMR1_INT,  _StateChange,   PBP,  yes
            INT_Handler    AD_INT,  _PulseLength,   PBP,  yes
    '@ INT_ENABLE TMR1_INT
    '@ INT_ENABLE AD_INT
    ADCON0 = %00000111
    'MAIN PROGRAM
    MAIN:
    pausea = 0
    WHILE PauseA <= 100
        PAUSEA = PAUSEA + 1
        pause 1
    wend
    toggle ledstatus
    GOTO MAIN
    'SUB PROGRAMS
    PulseLength:
    LENGTH.highbyte = ADRESH   'SET UP THE TIMER SET UP VARIABLES
    LENGTH.lowbyte = ADRESL
    toggle ledstatus1
    @ INT_RETURN ;RETURN
    StateChange:
    if pass = 5 then
        TOGGLE lEDOUT
        pass = 0
        pass = pass + 1
    TMR1H = LENGTH.highbyte 'Transfer the timer variables to the timer register
    TMR1L = LENGTH.lowbyte
    T1CON = %00010101
    ADCON0 = %00000111
    Thank you again for your assistance, you have been a real help.
    Andrew
