Labcentre Proteus Simulation software question
Results 1 to 5 of 5
    Default Re: Labcentre Proteus Simulation software question
    Thanks. Do you know any way where I can provide a minimum 0.5V and then increment 1.22mV on top. I have tried a few ways but couldn't do it precisely.
    ___________________
    WHY things get boring when they work just fine?
    You could use one of the 12-bit DAC's, which gives 1.221mV steps.
    A second PIC in the the .dsn with a couple buttons to control it should work.
    Here's an example that gives two 12-bit analog voltages using a DAC.
    A Virtual Terminal is used to set the voltages.
    http://support.melabs.com/threads/28...replaces-pots)
