PIC/Resonator ground/Power question. Need help (Little Bit urgent)
Results 1 to 4 of 4
    Dec 2010
    Default Re: PIC/Resonator ground/Power question. Need help (Little Bit urgent)
    1) It may be possible to make this work, but it depends on your circuit. The current limitation is for a whole device, not a pin. Each pin has a much lower limit, and if your 676s are driving something else, that has to be added to the total pin current. It's a highly unusual configuration. If you need to turn the devices off (sleep won't work), use the control pin to switch a FET to power them, don't directly power them.
    2) It's not just O.K., it's pretty much mandatory. A good design will have a single ground. Keep tracks short and ground tracks fat.
    3) It's not clear what happens to this common track when the 676's are powering up - do the 676's make this pin an output briefly and mess up the signal? Resistors to give the connections a bit of elasticity are a good idea, but your powering is most likely the root cause of the problems. The whole area of initial states and power-up / reset causes designers to rip their hair out regularly.
    I'd guess a combination of 1 & 3 is the root cause of your problem.
    Mar 2011
    Los Angeles, California
    Hi Megahertz!
    I would agree with Charles and he is correct, power is typically the problem when things become "spritual" (technical term). The only thing I would question is the use of capacitors with the resonators. Are you certain the resonators require caps? Most resonators I have worked with do not require external capacitors. Second I am guessing that on the output of the voltage regulator you have a 1 uf cap as close as possible and then a larger value cap somewhere else? It is also useful to "sprinkle" .1 uf caps in various places on the power buss. Best, Ed
