Microcode studio not showing data, though it is receiving it
Results 1 to 7 of 7
    Jan 2010
    Default Microcode studio not showing data, though it is receiving it
    Hi, I have a bluetooth module running at 3.5 volts with 3.3v TTL output connected to MAX232 to rs232 usb to serial converter. When I send data to the module, it should appear on the screen of the serial communicator. But instead what is happening is that the data is shown received at the Bytes Rx (at the bottom of the screen) as numbers increment there but it does not show on the screen.
    Can someone please help me know what am I doing wrong? My whole circuit is running at 3.5 volts including MAX232. Thanks
    Default Re: Microcode studio not showing data, though it is receiving it
    As a start, it would be helpful to know which model of max232 (check the datasheet for operating voltage).
    Jan 2010
    Maxim MAX232CPE
    Jan 2010
Size:  84.9 KBI tried the same at 5v now. Same result. The datasheet page is attached which says default baud is 9600. But the microcode window shows nothing but 'Bytes RX' increase by 5 everytime I send a '1'. Should it not increase by 8? Does that mean the datasheet says the wrong default baud?
    Does the MAX232 invert the signal? Does the default expect it to be inverted?
    Tina, First you need to check your Microcode >> Usb >> RS-232 >> Max-232. With everything connected except the Blue tooth module, short the RX/TX lines comming from the TTL level side of the Max-232. Now type something on your Microcode studio terminal application and you should see (if everything is wired correctly) the letters or numerals you are typing. If not, check each connection in the string. Once you have echo's of the typed characters then replace the short at the TTL side of the Max-232 with the connections to your Blue tooth module. Mine works GREAT.....
    EN82fn
    Aug 2013
  1. Receiving (Relatively) High Speed Serial Data
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2012, 11:16
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 21:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 13:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 22:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 10:20
