Pic18F4550 + SIMCOM SIM900D GSM/GPRS
Results 1 to 39 of 39
    Jun 2011
    Philippines
    Default Pic18F4550 + SIMCOM SIM900D GSM/GPRS
    Hello to everyone,
    I have a SIMCOM SIM900D GSM/GPRS module. I'm trying to make it communicate with the Pic18F4550 with 20Mhz crystal. But before that I made sure that the module is working/replying to AT commands by connecting it the serial port communicator via USB - TTL converter. And I confirmed that PC(Serial communicator) -> USB-TTL converter + GSM(Baud 115200) module are working.
    Then the next step I did is to try to send HSEROUT ["AT",13] to the GSM module..using hardware setup below
    and this is the code I'm using...
     asm
        __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
            DEFINE OSC 48
            DEFINE HSER_RCSTA 90h ' enable serial port,
            DEFINE HSER_TXSTA 36  ' enable transmit, * we change 20h to 36 for 115200
            DEFINE HSER_BAUD 115200
            DEFINE HSER_CLOERR  1 ' automatic clear overrun error
            TRISC  = %10000000    ' PORTC.7 is the RX input, PORTC.6 is the TX output
        '   Serial communication definition
    ADCON1 = %00001111      'Set up ADCON1 register no matter what you're doing!!!!!!
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    Serialdata var    byte
    INTCON2.7 = 0        ' Enable PORTB pull-ups
    TRISB = %11111000
    TRISC = %10000000
    led1 var PortC.0
    TRISD = %00000000
    Serout2 PORTD.5, 84, [$1B,$63,$30]  'cursor off for serial LCD
    Serout2 PORTD.5, 84, [$1B,$45,"SMS DEBUG PORT"]   ' serial LCD
    PORTB = 0            ' PORTB lines low to read buttons
       If PORTB.4 = 0 Then ' If 1st button pressed...
          HSEROUT ["Button 1",13]
          Serout2 PORTD.5, 84, [$1B,$45, "SMS DEBUG PORT"]
          Serout2 PORTD.5, 84, [$D, "Button 1 "]
          gosub GSM_CHECK
       Endif
       pause 200   ' pause to avoid sending repetation
    End   'End program
    GSM_CHECK:
    HSEROUT ["AT",13]                    'Send AT to modem followed by a CR
    HSERIN 5000, GSM_CHECK_ERR, [WAIT("OK")] 'Check OK reply, wait 5sec max.
    Serout2 PORTD.5, 84, [$D, "GSM OK"]
    High PORTB.0     ' 1st LED on
    PAUSE 1000
    low PORTB.0
     GSM_CHECK_ERR:
     Serout2 PORTD.5, 84, [$D, "GSM ERROR"]
     ;HSEROUT ["GSM_ERROR",13]
    I tried to interchange C6 and C7 lines but still I'm not getting "OK" response...hope anyone can give a me hint what I'm missing in my setup.
    Thanks in advance,
    tacbanon
    Default Re: Pic18F4550 + SIMCOM SIM900D GSM/GPRS
    A quick guess. You need to invert the signal. Try a max232 in between??
    Jun 2011
    Philippines
    Default Re: Pic18F4550 + SIMCOM SIM900D GSM/GPRS( a little sign of progress)
    Hi mackrackit,
    I did some more testing and the following codes works but still have some issues.
     asm
    endasm
            DEFINE OSC 48
    Serialdata var    byte[25]
    TRISB = %11111000
    TRISC = %10000000
    led1 var PortC.0
    TRISD = %00000000
    TRISB = %11111000
       If PORTB.6 = 0 Then ' If 3rd button pressed...
          PORTB.2 = 1      ' 3rd LED on
          Serout2 PORTD.5, 84, [$D, "Button 3 "]
          GOSUB GSM_SIGCHECK
          Endif
       If PORTB.5 = 0 Then ' If 2nd button pressed...
          PORTD.1 = 1      ' 2nd LED on
          Serout2 PORTD.5, 84, [$D, "Button 2 "]
          gosub GSM_MODEL
       Endif
       pause 240   ' pause to avoid sending repetation
    End   'End program
    GSM_SIGCHECK:
    HSEROUT ["AT+CSQ",13]                    'Send AT to modem followed by a CR
    HSERIN 4000, GSM_CHECK, [WAIT("AT+CSQ"),STR Serialdata\13] 'Check OK reply, wait 5sec max.
    Serout2 PORTD.5, 84, [$D, STR Serialdata\13]
    PAUSE 1000
    low PORTB.0
    GSM_CHECK_ERR:
    GSM_MODEL:
    HSEROUT ["AT+CGMI",13]                           'Ask model name
    HSERIN 4000, GSM_MODEL, [WAIT("AT+CGMI"),STR Serialdata\13]   'Check model name  "SIMCOM_Ltd"
    PAUSE 1000
    low PORTB.0
    After pressing each button (response displayed to the LCD) I need to press the RESET button of the LABX2 everytime.
    What do you think its causing this?
    tacbanon
    Again, just guessing..
    Maybe the module is sending something but not what is expected.
    Try moving the LED feed back to the beginning of the routine to see if it is stuck there.
    GSM_SIGCHECK:
    PAUSE 1000
    low PORTB.0
    PAUSE 1000
    Jun 2011
    Philippines
    GSM_SIGCHECK:
    PAUSE 1000
    low PORTB.0
    PAUSE 1000
    Hi macrackit,
    Thanks for helping me out...but I still have the same issue. It works only once and needs to hit the RESET button in order to read incoming value.
    tacbanon
    How far does it get before it locks up exactly?
    Is it receiving the AT+CSQ ?
    Jun 2011
    Philippines
    It locks up just right after it performs the first AT command..the same result when I rearrange the code.
    TRISB = %11111000
    ;gosub CLR_SCRN
    GOSUB GSM_SIGCHECK
    ;gosub CLR_SCRN
    gosub GSM_MODEL
    pause 260   ' pause to avoid sending repetition
    ;goto main
    End   'End program
    it perform GOSUB GSM_SIGCHECK then after it it never performs the gosub GSM_MODEL correctly and calls GSM_CHECK_ERR:
    I also tried to interchange the sequence but the same results. It performs the GOSUB GSM_MODEL but failed to execute GOSUB GSM_SIGCHECK correctly.
    /tacbanon
    I do not see anyplace in the code in post#3 to call GSM_CHECK_ERR
    And your last post has GOTO main commented out falling through to END.
    Maybe with all of the trouble shooting there are other typos? Sorry that I can not spot the problem directly.
    Sep 2009
    Try
    HSERIN [WAIT("CSQ: "),DEC Signal]
    SEROUT2 ....[DEC Signal]
    You don't have 13 chars, after AT+CSQ:...
    From manual
    STR ArrayVar\n{\c} Receive string of n characters optionally ended in character c
    So If you want to string end after receiving CRLF
    Try this
    Serialdata var byte[4]
    HSERIN 4000, GSM_CHECK, [WAIT("AT+CSQ"),STR Serialdata\4\13]
    Jun 2011
    Philippines
    @pedja089
    Thanks for the time helping..I tried the to call the following code below.
    GSM_SIGCHECK:
    PAUSE 1000
    low PORTB.0
    PAUSE 1000
    HSERIN 4000, GSM_CHECK_ERR, [WAIT("CSQ: "),DEC Signal]
    SEROUT2 PORTD.5, 84,[$D,DEC Signal]
    DEC Signal displays 14 which is I know it is correct. But when I try to call this block of code(pressing the 3rd button) 2nd time it calls GSM_CHECK_ERR...instead of 14. Works again if I press the RESET button.
    What do you think it is causing this issue?
    regards,
    tacbanon
    Jun 2011
    Philippines
    Sorry about that mackrackit...yeah I'm kinda dizzy now (been working on this since last night) below is the code what I was using.
     asm
    endasm
            DEFINE OSC 48
            DEFINE HSER_TXSTA 20h  ' enable transmit, * we change 20h to 36 for 115200
            DEFINE HSER_BAUD 9600
    Serialdata var    byte[13]
    TRISB = %11111000
    TRISC = %10000000
    led1 var PortC.0
    cntr var byte
    cntr = 0
    TRISD = %00000000
    gosub CLR_SCRN
    TRISB = %11111000
          gosub CLR_SCRN
          gosub CLR_SCRN
          GOSUB GSM_SIGCHECK
          Endif
         gosub CLR_SCRN
          gosub CLR_SCRN
          gosub GSM_MODEL
       Endif
       pause 260   ' pause to avoid sending repetation
    End   'End program
    GSM_SIGCHECK:
    PAUSE 1000
    low PORTB.0
    PAUSE 1000
    HSERIN 4000, GSM_CHECK_ERR, [WAIT("AT+CSQ"),STR Serialdata\13]
    GSM_CHECK_ERR:
    GSM_MODEL:
    PAUSE 1000
    low PORTB.0
    PAUSE 1000
    HSERIN 4000, GSM_CHECK_ERR, [WAIT("AT+CGMI"),STR Serialdata\13]   'Check model name  "SIMCOM_Ltd"
    CLR_SCRN:
    cntr=cntr+1
    Serout2 PORTD.5, 84, [$1B,$45,"GSM DEBUG PORT ",#cntr]
    Thanks in advance,
    tacbanon
    Jun 2011
    Philippines
    Oops I also forgot to mention that I'm using 9600 baud rate, I thought it will change anything...
    Sep 2009
    Check does it send correctly with HT. Use your usb ttl uart converter board.
    Try to send CRLF then pause 100, and then send command...
    Jun 2011
    Philippines
    On the SERIAL COMMUNICATORl, sending AT commands had no problems( w/ CR and CRLF).
    tacbanon
    Jun 2011
    Philippines
    I tried other serial communicator, and I'm not sure if I found the trouble...
    When I disable the Append New Line
    With New line after sending
    Do you think adding new line after each send will solve it - how?
    HSEROUT ["AT",13]
    HSERIN 4000, GSM_CHECK_ERR, [WAIT("OK")]
    The code above does not detect "OK".
    regards,
    tacbanon
    Sep 2009
    Try to connect PC to PIC, instead of modem...
    Also use Rx on PC board to sniff what is happening when pic and modem communicate...
    Jun 2011
    Philippines
    Default Troubleshooting...
    I tried to modify my hardware setup to detect whats going IN and OUT in the GSM module (below). I test each button(Button1-Button3) and each corresponding response of the GSM shown in the serial communicator.
    I noticed that everything seems normal..but when I tried the connection PIC-GSM... I have the same issue.
    So sending PIC to GSM AT commands is not issue..I think when receiving incoming data from GSM to PIC is where the trouble is.
    tacbanon
    Jun 2011
    Philippines
    Default Re: Troubleshooting...
    What I meant was, when I set the entire connection between PIC-GSM I have the trouble again(need to press the reset button on my Labx2 devboard)
    Jun 2011
    Philippines
    For testing I removed all HSERIN command to see if it will continue each line. And below is the results.
    Here is the code I'm using...
     asm
    endasm
            DEFINE OSC 48
    TRISB = %11111000
    TRISC = %10000000
    led1 var PortC.0
    cntr var byte
    cntr = 0
    TRISD = %00000000
    Serout2 PORTD.5, 84, [$1B,$45, "Start GSM SIMU"]   ' Serial LCD
    PAUSE 1000
    HSEROUT ["AT",13,10]                    'Send AT to modem followed by a CR
    pause 200
    cntr=cntr+1
    Serout2 PORTD.5, 84, [$1B,$45,"Start GSM SIMU"]
    Serout2 PORTD.5, 84, [$D,"AT -Done",#cntr]
    cntr=cntr+1
    HSEROUT["AT+CMGF=1",13]             'Here the GSM module is being entered in TEXT MODE.
    PAUSE 1000
    HSEROUT ["AT+CSQ",13,10]
    pause 200
    Serout2 PORTD.5, 84, [$D, "SIGNAL CHK",#cntr]
    PAUSE 1000
    HSEROUT ["AT+CGMI",13,10]                           'Ask model name
    pause 200
    cntr=cntr+1
    Serout2 PORTD.5, 84, [$D, "MANUFACT CHK",#cntr]
    Pause 1000
    Serout2 PORTD.5, 84, [$D,"GSM TEST DONE!",#cntr]
    End     ' End of program
    Can anyone pin point what I'm doing wrong in my code..and why HSERIN is not detecting data coming out from GSM?
    I Appreciate any help.
    Thanks in advance,
    tacbanon
    Sep 2009
    Maybe problem is in supply voltage. Modem works on 2.8V(it have internal regulator), so pic should work on 3.3V, and you must have serial resistor on pic TX. So modem can't draw any current from pic TX pin.
    Jun 2011
    Philippines
    Probably that is the case I'm having trouble with...serial resistor? Like a voltage divider?
    Here is the general Specification of the GSM
    Power Input:
    5V-7.5VDC @ 1.5A
    I/O Interface:
    UART 3.3V Logic 5V Tolerant
    tacbanon
    I still think you may need to use a max232 between the PIC and the device as you have mentioned the device works when connected directly to a PC.
    if that is the case,
    You can invert the comms for the pic18f4550. This will make it possible to talk to a modem without a rs232 chip: http://www.picbasic.co.uk/forum/showthread.php?t=10361
    http://www.scalerobotics.com
    Jun 2011
    Philippines
    Quote Originally Posted by ScaleRobotics View Post
    I found it on page 240(datasheet) BAUDCON: BAUD Rate Control Register
    Bit 4
    1 = TX data is inverted
    Bit 5
    1 = RX data is inverted
    Please correct me if I'm doing it wrong...
    Baudcon.4 = 1
    Baudcon.5 = 1
    regards,
    tacbanon
    That is correct. And make sure your voltages match, so no one gets hurt.
    Jun 2011
    Philippines
    Sorry to ask this...but to make sure. GSM module I/O Interface UART 3.3V Logic 5V Tolerant, connecting to my LABX2 I think is safe even with the modification of BAUDCON...am right?
    thanks for the help,
    tacbanon
    Are you using some kind of shield, or the SIM900D development board? Can you point me to a schematic for the one you have? If shield, did you connect some kind of rs-232 to connect it to your computer?
    Jun 2011
    Philippines
    Hi ScaleRobotics,
    Yes I'm using a shield..sorry I can not seem to find the schematic. I used USB -to TTL module to communicate with the PC.
    /tacbanon
    Sep 2009
    Usb-TTL serial module use true 3.3V uart.
    You port setup was ok, because you menage to get signal from modem, to pic, and send it to pc from pic...
    Also TX from pic is ok, because you get result(post 17) on PC when you connect USB module to modem tx...
    So check your ground, and check pic input type, maybe 2.8V isn't enough to ensure logic 1.
    Jun 2011
    Philippines
    @pedja089
    I checked the grounding..but still no changes.
    Sorry for being a noob, but I tried to get the voltage from GSM Tx(4.2v) Rx(4.9v). I also tried to use max232..and still no positive results...I'm totally lost
    /tacbanon
    Sep 2009
    I'm have board with sim900 connected to pic. Modem have 4V supply, pic have 3.3V.
    SIM900 use TTL 2.8V true uart, not inverted. I put just 2 resistor in series with comm lines.
    If you connect modem to rs232 side of max232, probably you frayed modem port.
    1. Connect modem and usb board, and check that.
    2. I tell you to try to connect your usb board to PIC instead of modem board. So you can check that communication is ok on PIC side...
    You didn't try that...
    So try to send response from PC to PIC. Only in HSERIN put longer timeout, eg 5s..
    3.You said in post 10 you menage to get signal level. So your hardware setup was ok.
    Jun 2011
    Philippines
    @pedja089
    Hi sorry took me so long to reply...in post #10 I was able to get the signal level only once(upon power on)...I have to reset my LabX2 to get the reading again. I will try to get another GSM module probably by next week to see if the result is the same...and post here the output. Thanks all for the help and more power to PBP forum!
    tacbanon
    Sep 2009
    If you get once reply from modem, your hardware was ok.
    Is anything was wrong you won't get reply if you restart or not...
    Hi tacbanon,
    I loaded your code from post 19 into a circuit here, and tested hserout with your settings. I couldn't seem to get anything out, unless I removed your brown out reset in the configs.
    If you change this line, does it help anything?
    ; __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
    As a side note, for 115200 baud on earlier code, I had to use:
    'DEFINE HSER_RCSTA 90h ' Enable serial port & continuous receive
    'DEFINE HSER_TXSTA 20h ' Enable transmit, BRGH = 0
    'DEFINE HSER_CLROERR 1 ' Clear overflow automatically
    'DEFINE HSER_SPBRG 25 ' 115200 Baud @ 48MHz, 0.16%
    Sep 2009
    Modem can draw up to 2A. So if you supply pic and modem from same power supply maybe voltage drops and lock your pic.
    Jun 2011
    Philippines
    Hi tacbanon,
    Hello ScaleRobotics, That did it...yipee!
    Thanks to you and thanks to everyone in the forum..
    tacbanon
    ghulamqadir90's Avatar
    ghulamqadir90 Guest
    any one plz send C source code of above
    Quote Originally Posted by ghulamqadir90 View Post
    This is NOT a "C" forum, it is as it's name implies a PIC BASIC Forum.
    Jul 2016
    PLZ send the source code of PIC BASIC
    • PIC BASIC
    • PIC BASIC
    BASIC
